Firmware C-Code for logging
I am using my own firmware with the DevPack and there are quite a few good examples for the functionalities.
What I am missing is an example for activating the logging on the CF Card.
I think that should be possible if the option is there with the configurator but the question is how.
Could you provide some informations about that?
Re: Firmware C-Code for logging
at the moment the logging feature is only available with the standard firmware we deliver with the PCAN-Router-Pro. Souce code examples for logging are not available at the moment.
Any hints how to implement that on your own?
See sample code "21_RTOS_FILESYSTEM"
i am sorry - the recommended sample is only available for the PCAN-Router Pro FD Version.
The older PCAN-Router Pro have no libs for file access to the CF card.
