delay in receive event
yesweCAN
Post by yesweCAN » Mon 7. Aug 2023, 18:24
In the CAN reading thread there is a loop which is waiting the Receive event.
I don't understand why there is a delay in the event ? , does it means that the event is generated only when the delay is passed ?
Re: delay in receive event
Post by PEAK-Support » Tue 8. Aug 2023, 08:25
As we do not know which sample you are talking about, it is hart to say.
But using the Windows Event could be used for
- wait infinity until event is triggered
- wait for xx ms
The first version is used when you run a own simply receiving thread, the second one is using when you have a high layer protocol where you have "time outs"
For example sending a CAN Frame to the Bus - and need to get a reply from a other node within xx ms.
See PCAN-Basic Parameter Documentation page 49+
yesweCAN
Post by yesweCAN » Tue 8. Aug 2023, 08:27
Sorry I'm talking about the c# GUI sample that read and write to CAN.
Post by PEAK-Support » Tue 8. Aug 2023, 09:03
OK - here the part (it is from the C++ BB sample) of the Thread:
DWORD TForm1::CANReadThreadFunc()
    TPCANStatus stsResult;
    DWORD result, dwTemp;
    // Sets the handle of the Receive-Event.
    stsResult = m_objPCANBasic->SetValue(m_PcanHandle, PCAN_RECEIVE_EVENT ,&m_hEvent, sizeof(m_hEvent));
    // If it fails, a error message is shown
    if (stsResult != PCAN_ERROR_OK)
        ::MessageBox(NULL, GetFormatedError(stsResult).c_str(), "Error!",MB_ICONERROR);
        return 1;
    // While this mode is selected
    while(rdbEvent->Checked)
        //Wait for CAN Data...
        result = WaitForSingleObject(m_hEvent, INFINITE);
        if (result == WAIT_OBJECT_0)
            ReadMessages();
    // Resets the Event-handle configuration
    dwTemp = 0;
    m_objPCANBasic->SetValue(m_PcanHandle, PCAN_RECEIVE_EVENT ,&dwTemp, sizeof(dwTemp));
    return 0;
As you could see - it use the "Infinite" Value
In C# /.Net it s handles like this
while (rdbEvent.Checked)
                // Waiting for Receive-Event
                if (m_ReceiveEvent.WaitOne(50))
                    // Process Receive-Event using .NET Invoke function
                    // in order to interact with Winforms UI (calling the
                    // function ReadMessages)
                    this.Invoke(m_ReadDelegate);
The Receive Event is here encapsulate in the -Net Framework (Namespace: System.Threading) see Windows .NET Specification for more info.
We need to use the Invoke function to interact with the User Interface.
yesweCAN
Post by yesweCAN » Tue 8. Aug 2023, 09:51
What is the meaning of the 50 in the c# sample.
I understand that the loop wait 50ms between each reading.
Post by PEAK-Support » Tue 8. Aug 2023, 09:58
No it wait max. 50 ms if no Event comes up. But if a Event comes in within this 50ms it goes directly to the Read Function, if no event is triggered it calls every 50ms the read function
(for Status Messages etc. and to interact with the UI, not for real CAN Frames ) If CAN Messages come for example every 1 ms the Event is triggered every 1mS and do not wait the 50 ms.
yesweCAN
Post by yesweCAN » Tue 8. Aug 2023, 10:03
Ok perfect thanks for this explanation.
I love your PCI board it works perfectly, and your sample are very usefull. :D
