Sorry - wrong Forum - you should contact people in a LabView Forum, or the maintainer of the LabView VI - but we are simply not able to help.
We do not know what your screens will do - it is simply not possible to understand your workflow from some pictures.
Try it with PLIN-View Pro - if it works there all is OK, you need to do the same in Labview.
Reading the data from the ECU using labview KDI drivers
Re: Reading the data from the ECU using labview KDI drivers
