Support for legacy software
I maintain 32-bit software that uses a 7841.dll to communicate with the PCI card. I was confronted with a (W10) system on which the CanOpenDriver(0,0) function returns the value -1 (PCI_INIT_ERROR). It is a PEAK IPEH-003026 and the hardware support person probably installed a current (64-bit) driver. I suspect that a 32-bit driver needs to be installed, but I can't find one on the PEAK site. I'm also not sure whether 7841.dll still provides the appropriate interface.
I would be grateful for any advice on how to solve the problem.
Re: Support for legacy software
Dear,
we do not know any 7841.dll and our APIs also do not return negative values on failure.
APIs from our company are canapi2.dll, canapi4.dll, pcanbasic.dll, pcan_pci.dll/pcan_2pci.dll (part of PCANLight API dlls), among others. Check if you find any of those files in your system.
Oh dear,
they replaced a PCI-7841-card from ADLINK by a card from PEAK.
So I have to replace the API in any case.
Can You help anyway, concerning the 32-bit-context?
I made the original software with pcan_dng.dll more than 20 years ago.
ich you have to implement the access to the PCAN-PCI card again, then use please the PCAN-Basic API for it. It offers support for x86 and x64 applications.
Please use the software PEAK-Drivers Setup to install both, the Plug&Play device drivers and the PCAN-Basic API.
The latest Version of this DLL from 2010 (Version 2.04) is available here - scroll down "Outdated APIs"I made the original software with pcan_dng.dll more than 20 years ago.
We decided to create a new software using C# under .net. Is there example code for this that could be used as a template? Preferably a Visual Studio solution.
As Keneth wrote - uset the PCAN-Basic API - he also add a link to the post. So simply study the Information / Package.
All you need is part of it...spend 2 minutes and you have what you need...
