I'm wondering, is there any possibility to program EWMA filter in PCAN-Router Pro? Basically I have a 12bit signal which I want to smoothen using EWMA filter and introduce back to CAN bus. I did this with PCAN router FD but, not sure how to do this in PCAN-Router Pro.
PCAN-Router Pro has a low-pass filter but, I want to go beyond 1st order smoothning.
EWMA function on PCAN-Router Pro
Re: EWMA function on PCAN-Router Pro
the PCAN-Router Pro can also be used/flashed with an own application/firmware. You don't need to use the standard firmware for this. Simply build a firmware for PCAN-Router Pro with your EMWA filter using our PEAK-Dev package, as you have done with PCAN-Router FD. Please use one of the examples for PCAN-Router Pro as a template.
Thanks a lot.
I cannot locate "Yagarto GNU ARM toolchain for Windows" in your website. Can you please help me to locate? Also, any tutorial guide to use it?
Thanks Again
Thanks Again
The "Yagarto GNU ARM toolchain for Windows" is outdates since some years.
Please download the ARM-Developer Package - this is one package for all µC based unites with ARM cores - also PCAN-Router PRO. (see product description / download section of product)
