PCAN-ISO-TP-Unable to initialize the Receiver channel
Pujari
Post by Pujari » Mon 9. Oct 2023, 13:40
I am trying python PCAN-ISO-TP sample. 08_canfd_read_write. When run the canfd_read_write.py, Tx channel is getting initilized, but the Rx channel is not getting initialized. Please see the below msg. Could you guide me, what could be the issue.
C:\Project\Jira\pcan\PCAN-ISO-TP\Samples\Samples\Python\08_canfd_read_write>canfd_read_write.py
PCAN-ISO-TP API Version:  b'3.5.0.344'
Initialize transmitter:  OK
Initialize receiver:  KO
Create a receive event on receiver:  KO
Allocate tx message:  OK
Allocate rx message:  OK
Write "42" message:  OK
Wait a message on receiver:  KO
Free tx message:  OK
Free rx message:  OK
Stop receive event on receiver:  KO
Close receive event:  OK
Uninitialize transmitter:  OK
Uninitialize receiver:  KO
Re: PCAN-ISO-TP-Unable to initialize the Receiver channel
Post by K.Wagner » Mon 9. Oct 2023, 14:22
could you please tell us which PCAN hardware are you using?
Pujari
Post by Pujari » Mon 9. Oct 2023, 14:27
Am using PCAN-USB with windows 10 PC
Post by K.Wagner » Mon 9. Oct 2023, 14:34
do you mean, that you have only one PCAN-USB (one channel) connected to your PC? If it is so, then the problem is clear. You need one physical channel for each connection.
Pujari
Post by Pujari » Mon 9. Oct 2023, 14:39
Thanks for reply.
Actually its PCAN-USB FD. So if I understand correctly, we need to connect, two PCAN-USB FD, one for Transmission and other for Reception. Please confirm.
Regards.
Anand Pujari
Post by K.Wagner » Mon 9. Oct 2023, 14:46
Hello again,
Yes. As said before, you need one physical channel per connection. Our fee free APIs do not allow connecting the same physical channel more than once at the same time.
Please note that you can use different PCAN hardware, for instance, one PCAN-USB FD and one PCAN-PCIe card.
