Cant compile the Peak Linux Drivers
Locked
Terje
Post by Terje » Fri 12. Jan 2024, 14:31
Hey.
I have been using Peak Linux Drivers and PcanBasic for about 3 years now.
I'm using partly Raspberry Pi with Raspbian, And mostly Ubuntu.
In this case I have compiling problems under Ubuntu 22.12.3.
Kernel linux-headers-6.5.0-14-generic.
Peak Drivers 8.16.0.
I have been working on my computer for several months, and suddenly the PCan fails to work.
It looks like the CharDev is the problem, resulting in gcc: error: unrecognized command-line option ‘-ftrivial-auto-var-init=zero’.
Trying to reinstall I get following information.
:~/can/peak-linux-driver-8.16.0$ make clean all
make[1]: Går till katalogen ”/home/pls/can/peak-linux-driver-8.16.0/driver”
rm -f src/*o src/*~ src/.*cmd *o *ko *~ .*cmd pcan.mod.c Module.symvers modules.order .cache.mk
make[1]: Lämnar katalogen ”/home/pls/can/peak-linux-driver-8.16.0/driver”
make[1]: Går till katalogen ”/home/pls/can/peak-linux-driver-8.16.0/lib”
rm -f src/*~
rm -rf obj lib obj32 lib32
make[1]: Lämnar katalogen ”/home/pls/can/peak-linux-driver-8.16.0/lib”
make[1]: Går till katalogen ”/home/pls/can/peak-linux-driver-8.16.0/test”
make[1]: Lämnar katalogen ”/home/pls/can/peak-linux-driver-8.16.0/test”
make[1]: Går till katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic”
*** Processing 'pcanbasic' directory...
make[2]: Går till katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/pcanbasic”
*** Cleaning PCANBasic library...
rm -f src/*~ out/*.o out/*.gcno *~ *.so.* *.so lib/*~ lib/*.so.* lib/*.so lib32/*~ lib32/*.so.* lib32/*.so out32/*.o out32/*.gcno
make[2]: Lämnar katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/pcanbasic”
*** Processing 'pcaninfo' directory...
make[2]: Går till katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/pcaninfo”
*** Cleaning pcaninfo...
rm -f src/*~ src/*.o ../pcanbasic/src/*~ ../pcanbasic/src/*.o *~ *.so.* *.so pcaninfo.1.3.1 pcaninfo
make[2]: Lämnar katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/pcaninfo”
*** Processing 'examples' directory...
make[2]: Går till katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples”
*** Processing 'C' directory (console examples)...
make[3]: Går till katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/c”
*** Cleaning PCANBasic C examples
make[3]: Lämnar katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/c”
*** Processing 'NativeC++' directory (console examples)...
make[3]: Går till katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++”
*** Cleaning PCANBasic C++ examples...
make[4]: Går till katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++/01_LookUpChannel”
rm -f *.o *~ ../LookUpChannel
make[4]: Lämnar katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++/01_LookUpChannel”
make[4]: Går till katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++/02_GetSetParameter”
rm -f *.o *~ ../GetSetParameter
make[4]: Lämnar katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++/02_GetSetParameter”
make[4]: Går till katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++/03_ManualRead”
rm -f *.o *~ ../ManualRead
make[4]: Lämnar katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++/03_ManualRead”
make[4]: Går till katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++/04_ManualWrite”
rm -f *.o *~ ../ManualWrite
make[4]: Lämnar katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++/04_ManualWrite”
make[4]: Går till katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++/05_TimerRead”
rm -f *.o *~ ../TimerRead
make[4]: Lämnar katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++/05_TimerRead”
make[4]: Går till katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++/06_TimerWrite”
rm -f *.o *~ ../TimerWrite
make[4]: Lämnar katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++/06_TimerWrite”
make[4]: Går till katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++/07_ThreadRead”
rm -f *.o *~ ../ThreadRead
make[4]: Lämnar katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++/07_ThreadRead”
make[4]: Går till katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++/08_EventDrivenRead”
rm -f *.o *~ ../EventDrivenRead
make[4]: Lämnar katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++/08_EventDrivenRead”
make[4]: Går till katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++/09_TraceFiles”
rm -f *.o *~ ../TraceFiles
make[4]: Lämnar katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++/09_TraceFiles”
make[3]: Lämnar katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples/NativeC++”
make[2]: Lämnar katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic/examples”
make[1]: Lämnar katalogen ”/home/pls/can/peak-linux-driver-8.16.0/libpcanbasic”
*** Host OS Release=Ubuntu v22.04
*** Host machine kernel version=6.5.0-14-generic
*** Driver kernel version=6.5.0-14-generic (6.5.0)
*** Path to kernel sources=/usr/src/linux-headers-6.5.0-14-generic
*** use KBUILD=yes
*** use DKMS=
*** gcc version=11
make -C /usr/src/linux-headers-6.5.0-14-generic EXTRA_CFLAGS="-I/home/pls/can/peak-linux-driver-8.16.0/driver -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DNO_DONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNO_NETDEV_SUPPORT -DNO_RT -Wno-date-time" V=0 modules M=/home/pls/can/peak-linux-driver-8.16.0/driver
make[2]: Går till katalogen ”/usr/src/linux-headers-6.5.0-14-generic”
warning: the compiler differs from the one used to build the kernel
The kernel was built by: x86_64-linux-gnu-gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
You are using:
CC [M] /home/pls/can/peak-linux-driver-8.16.0/driver/src/pcan_main.o
make[4]: *** [scripts/Makefile.build:251: /home/pls/can/peak-linux-driver-8.16.0/driver/src/pcan_main.o] Fel 1
make[3]: *** [/usr/src/linux-headers-6.5.0-14-generic/Makefile:2037: /home/pls/can/peak-linux-driver-8.16.0/driver] Fel 2
make[2]: *** [Makefile:234: __sub-make] Fel 2
make[2]: Lämnar katalogen ”/usr/src/linux-headers-6.5.0-14-generic”
make[1]: *** [Makefile:523: all] Fel 2
make: *** [Makefile:84: all] Fel 2
BR
Terje.
Re: Cant compile the Peak Linux Drivers
Post by PEAK-Support » Fri 12. Jan 2024, 14:36
This error is an error that comes when installing a to recent kernel. See link
Terje
Post by Terje » Fri 12. Jan 2024, 14:48
Hey.
Forgot to tell that i use Pcan-USB IPEH-002021.
Well.
I have tried doing following:
sudo apt uninstall gcc -y
sudo apt autoremove -y
sudo apt install gcc-12 -y
Restart.
Now gcc is missing. Fail.
sudo apt install gcc -y
Restart and compile. Result is the same.
I'm about to do a reinstall of Ubuntu, but not sure if it will help.
Anyways, it would also be good on how to solve this issue. Because it happens now and then.
/Terje.
Post by PEAK-Support » Sun 14. Jan 2024, 18:21
We have removed your last post.
We now have contact you by e-mail. It makes absolutely no sense to post in a Forum hundreds lines of your try to fix a problem.
Locked
