Source and destionation address?
sandeepc
Post by sandeepc » Mon 8. Apr 2024, 13:25
I want send huge data (in Mb) from Visual studio code (PC) to MCU?
Hardware using: PCAN-USB FD
So as i gone through CAN protocol if want send huge data we have use ISO TP (ISO 15765-2). PCAN-USB FD it supports this iso format.
I gone through the complete (ISO 15765-2) address formatting and can tp working.
Links removed! Please read the rules. no external links, please rules.php
I downloaded resources from peak website:
https://www.peak-system.com/PCAN-ISO-TP ... .html?&L=1
I gone through the all examples and i am able to build and run the 06_isotp_segmented_read_write successfully.
MCU configuration: CAN Reception ID =0xA1,CAN Transmission ID: 0xA2
i have few queries on mapping:
This ID is my MCU ID?
mapping.can_id = 0xA1;
The MCU should response to this address right?
mapping.can_id_flow_ctrl = 0xA2;
	mapping.can_msgtype = PCANTP_CAN_MSGTYPE_STANDARD;
//dlc will overwrittenduring msg data init right?
mapping.can_tx_dlc = 0x0;
Not applicable Due to 11 bit identifier
mapping.netaddrinfo.extension_addr = 0x00;
	mapping.netaddrinfo.format = PCANTP_ISOTP_FORMAT_NORMAL;
	mapping.netaddrinfo.msgtype = PCANTP_ISOTP_MSGTYPE_DIAGNOSTIC;
normal adressing format from ISO 15765-2 so its not required source and destination address why still we need to use these address?
mapping.netaddrinfo.source_addr = 0xF1;
	mapping.netaddrinfo.target_addr = 0x01;
since i used PCAN-USB FD so i leave as it is
mapping.netaddrinfo.target_type = PCANTP_ISOTP_ADDRESSING_PHYSICAL;
below is it configuring for to triggerr when data available on USB1 or what purpose below configuration we have to use?
// Create the associated reversed mapping:
	reverse_mapping = mapping;
	reverse_mapping.can_id = mapping.can_id_flow_ctrl;
	reverse_mapping.can_id_flow_ctrl = mapping.can_id;
	reverse_mapping.netaddrinfo.source_addr = mapping.netaddrinfo.target_addr;
	reverse_mapping.netaddrinfo.target_addr = mapping.netaddrinfo.source_addr;
to send huge data i configured as below
	mapping.netaddrinfo.msgtype = PCANTP_ISOTP_MSGTYPE_FLAG_INDICATION_TX;
1st try
2nd try
mapping.netaddrinfo.source_addr = 0x00;
	mapping.netaddrinfo.target_addr = 0x00;
when i use above configuration(PCANTP_ISOTP_MSGTYPE_FLAG_INDICATION_TX) vs code does not sending any messages it self, why?
If want to send huge what are the modification required in 06 example?
Sandeep C
Re: Source and destionation address?
Post by M.Heidemann » Mon 8. Apr 2024, 14:52
Hello Sandeep,
regarding your post:
1.
These are the CAN-IDs which are used to match the ISOTP networking information.
2.
Not applicable since normal ormal addressing is used.
3.
This is wrong, ISO-TP always uses Source and Target Address. But with normal addressing there is a mapping between Adresses and CAN IDs.
4.
This is wrong. The device has nothing to do with ISOTP addressing type (physical=point-to-point communication and functional=broadcasting)
5.
It is required to configure a 2 way communication when one need to transmit segmented messages (because there are protocol frames that are sent from and to each peer).
Please see example #6 provided in the PCAN ISO-TP API packgage. In the example two ISO-TP nodes are initialized.
If you want to transmit data to an ECU, only one channel must be initialized (called transmitter_handle in the sample).
Also, i have to address:
Please try and use some form of formatting or make use of the code tags,
i'll add them this time around but consider using them in the future.
