Digital IN/OUT on PCAN-GPRS LINK
Locked
robinguillaume
Post by robinguillaume » Wed 20. Mar 2013, 12:28
Two questions:
i am testing Digital inputs Do and D1 on PCAN-GPRS Link.
it seems that DInO and Din1 are inverted compared to the User Manual DIn0 is on Pin 6 and Din1 is on pin 7.
can you confirm?
in the User manual p37
Inputs 2 Low- or High-active (depending on the pull-up/-
down wiring)
why depending on the pull-up/ pull down? do we have to put a pull resistance?
From what i can measure, It seems that a pull up resistance is already mounted in the box?
S.Michaelsen
Hardware Development
Re: Digital IN/OUT on PCAN-GPRS LINK
Post by S.Michaelsen » Wed 20. Mar 2013, 13:46
yes the names seems to be switched in the software library.
There is a pull up soldered on the board but there is also the possibility to remove it and place a pull down resistor instead.
Best Regards,
Stephan Michaelsen
robinguillaume
Post by robinguillaume » Wed 20. Mar 2013, 14:36
Thanks.
I note
Best regards
Post by PEAK-Support » Thu 21. Mar 2013, 08:57
closed
Locked
