Reading send messages
matthieu
Post by matthieu » Mon 15. Jul 2024, 16:30
I'm currently using worker to read and send messages to CAN network but I don't get how I can read the messages that I'm sending.
Matthieu.
Re: Reading send messages
Post by M.Maidhof » Mon 15. Jul 2024, 17:23
by default you won't receive your send messages in a CAN system. But there are features available in our API to return the transmitted messages again. Which API and PCAN hardware (firmware) do you use?
matthieu
Post by matthieu » Tue 16. Jul 2024, 08:55
thanks for the response, I'm currently using Peak.PCANBasic.NET (v. 4.9.0.942).
I'm using the worker on the namespace Peak.Can.Basic.
Br,
Matthieu
Post by M.Heidemann » Tue 16. Jul 2024, 09:41
Hello Matthieu,
Which hardware do you use and which firmware is on the device?
Depending on this, you might be able to use "ALLOW_ECHO_FRAMES" in PCANBasic.
matthieu
Post by matthieu » Tue 16. Jul 2024, 10:33
PCAN-USB
Firmware version: 8,6,1
Post by M.Heidemann » Tue 16. Jul 2024, 10:45
Hello Matthieu,
In this case you can use the AllowEchoFrames property of the worker class:
https://docs.peak-system.com/API/PCAN-B ... d756cf.htm
This parameter helps the user to allow / disallow the reception of echo messages within a
PCAN-Channel, this is, the reception of frames sent by itself. This parameter doesn’t affect
the acceptance filter of the PCAN-Channel. Furthermore, other applications working with the
same PCAN-Hardware can individually configure the reception of echo frames.
Note that disabling the PCAN_RECEIVE_STATUS parameter also suppresses the reception of
echo frames.
