Measuring CAN Frame Runtime between two PCAN-USB FD devices.
CAN FD Interface for High-Speed USB 2.0
kundewayne
Post by kundewayne » Wed 7. Aug 2024, 04:33
On a Windows 10 machine, I'm using two PCAN-USB FD interfaces that are connected via external hardware. My goal is to determine how long it takes for a CAN frame to move from one device to another.
I tried PCAN-View, but the timestamps on the Trace tab appear to be independent of each instance. Is it possible to synchronize these timestamps with system time? Can I monitor both PCAN-USB ports from a single PCAN-View instance?
Any suggestions on how to precisely calculate frame transit time would be highly appreciated.
PEAK-System
Re: Measuring CAN Frame Runtime between two PCAN-USB FD devices.
Post by PEAK-System » Wed 7. Aug 2024, 09:11
Is it possible to synchronize these timestamps with system time? -> they are already based on system-time.
Can I monitor both PCAN-USB ports from a single PCAN-View instance? -> no.
Any suggestions on how to precisely calculate frame transit time would be highly appreciated. -> Maybe use PCANBasic and write a little application that does so?
kundewayne
Post by kundewayne » Thu 8. Aug 2024, 03:17
Thank you for your response; I do not have any further inquiriesgorilla tag.
Post by M.Heidemann » Thu 8. Aug 2024, 09:23
Furthermore, as i didn't mention it.
You could also use PCAN-Explorer 6 to trace 2 or more busses at the same time,
if you don't feel comfortable writing your own application.
We also issue a trial for PCAN-Explorer 6, if you are interested contact us! -> support[at]peak-system.com
