I have trying to use cantools with pcan for CAN FD
however I got a error message below and can you advise me what else should I add or correct?
"A parameter contains an invalid value"
import cantools
import can
import time
bus = can.interface.Bus(channel='PCAN_USBBUS1', interface='pcan', bitrate=500000, data_bitrate=2000000, fd=True)
cantools with pacn for CAN FD
- pcan.jpg (62.22 KiB) Viewed 14983 times
Re: cantools with pacn for CAN FD
If I set it as below, it works for only CAN 500K not CAN FD... even if fd is set True.....
bus = can.interface.Bus(channel='PCAN_USBBUS1', interface='pcan',bitrate=500000, data_bitrate=2000000,fd=True,f_clock=80000000,nom_brp=2,nom_tseg1=63,nom_tseg2=16,nom_sjw=16,data_brp=2,data_tseg1=15,data_tseg2=4,data_sjw=4)
What does not work? Sending CAN Frames with the Fast Bitrate ? Are you sure you have Set the BRS Bit?
