sade54
Post
by sade54 » Thu 17. Oct 2024, 17:13
I'm trying to start a macro designed for PCAN explorer 5 on version 6.7.0.2830 (Microsoft Windows 11 Pro 23H2 (10.0.22631) x64).
But I have an error triggering on this line :
Set client = CreateObject("PCAN3.PCANClient")
I have then this window:
I have the same on another .pem file , at the same command.
Post
by M.Heidemann » Fri 18. Oct 2024, 08:55
Change PCAN3.PCANClient in your macro to PCAN4.PCANClient and you should be golden!
(PCAN-Explorer 6 uses the PCAN-API 4, PE5 did use PCAN-API 3 in later Versions)
BR
sade54
Post
by sade54 » Fri 18. Oct 2024, 09:20
Thanks, it did the trick !
