I am building a C# application to flash an ECU via UDS.
My hardware setup includes 3 USB PeakCAN devices.
Problem description:
When I flash on CAN1, it works correctly.
However, if I call Initialize or Uninitialize on CAN2 or CAN3 during the flashing process, the RX buffer of CAN1 gets cleared, which causes the flashing to fail.
I already checked that the handles for the 3 CAN channels are different.
Questions:
Is there any known issue with the PCAN-Basic API where calling Initialize or Uninitialize on another channel clears the RX buffer of an already active channel?
Do I need to use a specific initialization sequence to avoid this problem?
Is there a recommended way to handle multiple USB PeakCAN devices in parallel without interfering with each other’s RX buffers?
Any advice or hints would be highly appreciated.
Thank you,
Issue with RX buffer cleared when initializing/uninitializing other CAN channels (C# / PCAN-Basic)
Re: Issue with RX buffer cleared when initializing/uninitializing other CAN channels (C# / PCAN-Basic)
please send us an email and referr to this topic, use the following email address: support.peak@hms-networks.com
