Build Sample Code from PEAK System
Weber_Hong
Post by Weber_Hong » Mon 5. Jan 2026, 08:28
We are trying to build the C# sample code - PCAN-UDS API from PEAK SYSTEM
An exception occurred indicating that PCAN-UDS.dll could not be found, so we added PCAN-UDS.dll to the system folders (both System32 and SYSWOW64).
After trying to build the code again, a BadImageFormatException occurred.
Since we copied the files manually, did we miss anything, or is there something that needs to be installed in order for it to run properly?
Thank you!
Re: Build Sample Code from PEAK System
Post by G.Lang » Mon 5. Jan 2026, 11:00
please send an email to "info.peak@hms-networks.com" and refer to this forum post.
