Unable to compile PEAK driver on Kubuntu 25 (kernel 6.17) missing pcan_common.h
Starik
Post by Starik » Tue 9. Dec 2025, 10:08
I’m trying to compile the peak-linux-driver on Kubuntu 25 with kernel 6.17.0-7-generic, and I get the following error when running `make`:
fatal error: src/pcan_common.h: No such file or directory
36 | #include "src/pcan_common.h"
compilation terminated.
However, the file does exist:
./driver/src/pcan_common.h
Kernel headers are installed:
linux-headers-6.17.0-7-generic
I am compiling from the project root directory, but the issue persists.
I’m wondering if driver version 8.20.0 is incompatible with newer kernels such as 6.17.
Could you confirm whether there is a driver version compatible with this kernel (8.20.1 or newer), or provide a patch to enable compilation?
For the moment I am using socket for testing but I am not sure if this could be valid for CAN FD?
Thank you in advance for your help.
S.Grosjean
Re: Unable to compile PEAK driver on Kubuntu 25 (kernel 6.17) missing pcan_common.h
Post by S.Grosjean » Tue 9. Dec 2025, 10:29
Yes, you're right: in order to fix that issue, you should download the pre release of the next version of PCAN from: https://cavok.peak-system.com/X9EkN5L.
Starik
Post by Starik » Tue 9. Dec 2025, 14:10
I downloaded the package, compiled it, and installed it:
make clean
make
sudo make install
The driver is installed, and SavvyCAN can see usb0.
I tried to test that everything is okay, so I tried to use the test folder.
I didn't manage to run a test.
I tried to use can0 via socket like I have done before, but the script I use is not working either.
Did I miss something? Am I not doing it correctly?
case "$1" in
    start)
        echo "========================================"
        echo "   PCAN-USB / SocketCAN START           "
        echo ""
        echo "[1] Vérification de l'existence de can0..."
        if ! ip link show can0 &>/dev/null; then
            echo "ERREUR : L'interface can0 n'existe pas."
            echo "→ Le driver peak_usb n'est peut-être pas chargé ?"
            exit 1
        fi
        echo "OK, can0 détecté."
        echo ""
        echo "[2] Mise en DOWN..."
        sudo ip link set can0 down || { echo "ERREUR en mettant can0 down."; exit 1; }
        echo "can0 est DOWN."
        echo ""
        echo "[3] Configuration du bitrate ($BITRATE)..."
        sudo ip link set can0 type can bitrate $BITRATE || { echo "ERREUR : impossible de configurer le bitrate."; exit 1; }
        echo "Bitrate OK."
        echo ""
        echo "[4] Mise en UP..."
        sudo ip link set can0 up || { echo "ERREUR : impossible de passer can0 en UP."; exit 1; }
        echo "can0 est UP."
        echo ""
        echo "[5] État complet :"
        ip -details -statistics link show can0
        echo ""
        echo "========= PCAN-USB opérationnel ========="
this code returns:
here how i use the test exemple:
xxxxxx:~/Downloads/peak-linux-driver-8.21.2-beta/test$ sudo transmitest transmit.txt
[sudo: authenticate] Password:
transmitest Version "Release_20150610_n" (www.peak-system.com)
------- Copyright (C) 2004-2009 PEAK System-Technik GmbH ------
transmitest comes with ABSOLUTELY NO WARRANTY. This is free
software and you are welcome to redistribute it under certain
conditions. For details see attached COPYING file.
transmitest: device node="/dev/pcan0"
Only standard frames are sent, init with 500 kbit/sec.
Data will be read from "transmit.txt".
transmitest: can't open /dev/pcan0
transmitest: finished (2).
xxxxxx:~/Downloads/peak-linux-driver-8.21.2-beta/test$ cat /proc/pcan
*------------- Beta____20251023_n (8.21.2) Dec 9 2025 10:33:50 --------------
*---------------------- [mod] [isa] [pci] [pec] [usb] -----------------------
*--------------------- 1 interfaces @ major 509 found -----------------------
xxxxxxx:~/Downloads/peak-linux-driver-8.21.2-beta/test$
Starik
Post by Starik » Tue 9. Dec 2025, 14:39
ah yes i didn't install the 'make netdev', now its working. but i didn't run peak tests.
still could not run tests from the folder test.
Post by M.Maidhof » Wed 10. Dec 2025, 08:17
if you run the driver in NetDev mode, you can't use the tools from the test directory. Those tools will only work with the chardev driver. Please install can-utils, to have the test tools for SocketCAN/NetDev available (candump, cansend, cansniffer ...)
janodw
Post by janodw » Mon 12. Jan 2026, 11:34
S.Grosjean wrote: ↑
this solution should help in my case as well, however the download link you shared seems to have expired.
Could you please prepare the file again or provide a new link for download?
Thank you
S.Grosjean
Post by S.Grosjean » Tue 13. Jan 2026, 12:43
Here is new link: https://cavok.peak-system.com/XGVvI1F
