Error when setting PCAN_TRACE_LOCATION for same folder multiple times
PranavBodke
Post by PranavBodke » Tue 20. Jan 2026, 10:04
Hello Team,
I am facing an issue while configuring the trace file location using PCAN-Basic API.
When I set TPCANParameter.PCAN_TRACE_LOCATION to a specific folder for the first time, it works correctly.
However, when I try to set the same folder again, the API returns an error.
Code snippet:
ushort channelUsed = PCANBasic.PCAN_USBBUS1;
string tracesFolder = System.IO.Path.GetTempPath();
string fullPath;
fullPath = System.IO.Path.Combine(tracesFolder, "PCAN-Basic_Flashing");
System.IO.Directory.CreateDirectory(fullPath);
if (PCANBasic.Initialize(channelUsed, TPCANBaudrate.PCAN_BAUD_500K) == TPCANStatus.PCAN_ERROR_OK)
    if (PCANBasic.SetValue(
            channelUsed,
            TPCANParameter.PCAN_TRACE_LOCATION,
            fullPath,
            (uint)fullPath.Length) == TPCANStatus.PCAN_ERROR_OK)
        Console.WriteLine("Trace location set successfully");
    else
        Console.WriteLine("Error while setting trace location");
Observation:
- First time setting trace location → Success
- Setting same folder again → Error
Is PCAN_TRACE_LOCATION required to be set only before Initialize()?
Is Uninitialize() required before setting it again?
Any guidance would be appreciated.
Pranav Bodke
Reason: code formatting
Re: Error when setting PCAN_TRACE_LOCATION for same folder multiple times
Post by M.Maidhof » Tue 20. Jan 2026, 10:37
which version of the PCANBasic API and driver do you use?
