I'm not able to connect either PCAN-Explorer or PCAN-View to a net onto Virtual Driver.
If I look at Network Configuration utility I can see Virtual->Internal->TestNet (my net).
But if I try to connect using PCAN-View or PCAN-Explorer I get all nets except nets on Virtual Driver.
What I'm doing wrong?
PCAN-Explorer or PCAN-View Virtual Driver
Re: PCAN-Explorer or PCAN-View Virtual Driver
which version of PCAN-View and PCAN-Explorer 5 do you use?
I'm using
PCAN-View version 3.2.3.221
PCAN-Explorer version 5.3.1.794
I just want to correct my post. PCAN-View is able to detect virtual-driver. I can see Internal->TestNet@Virtual on the connection Windows.
PCAN-Explorer I can only see USB tab on the connection Windows.
please post a screenshot of the connection dialog of PCAN-Explorer, maybe the virtual driver tab is just out of sight, and you have to use the two buttons in the top right corner to scroll to the virual driver:
Ok,
here three scrennshot: PCAN-NetConfiguration, PCAN-Hardware with driver version, PCAN-Explorer Add Connection dialog window.
Ciao,
Andrea
Ciao,
Andrea
HI,
ok, now I think I know why you didn´t see the virtual driver. You have already a PCAN-USB connection in use in PE5, than PCAN-Explorer could only connect to another USB connection, and not to a connection of another device. You simply have to remove your connections in your project, or start a new project, to have access to the virtual driver.
BTW: you are using an older pcan_usb.sys driver 3.5, please update to version 3.8.2, by installing the latest PeakOemDrv.exe: http://www.peak-system.com/produktcd/Dr ... OemDrv.exe
Yes,
it solves the problem.
