Canalyzer trace import
BitTuomas
Post by BitTuomas » Wed 23. Feb 2011, 14:07
Is it possible to import .asc format trace files to PCAN Explorer 5? It seems that is has been possible with PCAN Explorer 4.
BitTuomas
Re: Canalyzer trace import
Post by BitTuomas » Wed 23. Feb 2011, 16:53
Answer to my self. To view canalyzer traces with PCAN exporer they must be opened, not imported.
This brings up another point. There is a header part in the trace and PCAN exporer does not understand all of it. At least version of the headerthat my trace files have.
date Wed Feb 23 03:38:08 am 2011
base hex  timestamps absolute
internal events logged
// version 7.1.1
Begin Triggerblock Wed Feb 23 03:38:08 am 2011
After removing three middle lines from the trace file PCAN explorer was able to open the trace.
Post by PEAK-Support » Sat 26. Feb 2011, 12:37
We have a converter Tool which could convert different Log file types.
Information for current Version 1.7
Input:
- PCAN-Trace, PCAN-Explorer Trace (trc/crd)
- PCAN-Router Pro Binary Trace (btr)
- ASCII (asc)
Output:
- trc/crd/btr --> asc
- trc/btr multichannel --> trc split to single channel
- asc --> trc
download core-converter unzip to local directory - no installation necessary.
GFDigraziano
Post by GFDigraziano » Fri 14. Mar 2014, 16:47
The link to download core-converter is no more available. Could you please post a "working" link?
Thanks a lot,
best regards.
GFDigraziano
Post by GFDigraziano » Fri 14. Mar 2014, 16:59
GFDigraziano wrote:The link to download core-converter is no more available. Could you please post a "working" link?
Thanks a lot,
best regards.
Found it! :)
Here the link: http://www.peak-system.com/fileadmin/me ... verter.zip
Post by PEAK-Support » Sun 16. Mar 2014, 12:20
Thank You - i also fixed the link in my original Post!
GFDigraziano
Post by GFDigraziano » Wed 2. Apr 2014, 12:06
Excuse me, which software has to be used to analyze .trc files off line? Is it free?
Post by PEAK-Support » Wed 2. Apr 2014, 12:16
it´s a text based file - so you could read with any Text Editor :-)
Here a sample:
;$FILEVERSION=1.3
;$STARTTIME=40382.5618606097
;   C:\Pruefstand-Biblis-BlockA\Traces\Kernschmelze-Simu.trc
;   Start time: 23.07.2010 13:29:04.756.6
;   Bus  Name  Connection     Protocol
;   1    500K  500K@pcan_usb  CAN
;   Message Number
;   |         Time Offset (ms)
;   |         |       Bus
;   |         |       |    Type
;   |         |       |    |       ID (hex)
;   |         |       |    |       |    Reserved
;   |         |       |    |       |    |   Data Length Code
;   |         |       |    |       |    |   |    Data Bytes (hex) ...
     1)         1.000 1  Rx        01C5 -  8    2D B4 2B 42 2D C7 00 00
     2)         1.300 1  Rx        01A1 -  8    00 28 25 00 00 00 62 00
     3)         1.500 1  Rx        01C3 -  8    07 20 08 FC 00 00 75 00
     4)         1.800 1  Rx        01C4 -  8    13 62 C2 57 00 00 00 00
     5)         2.000 1  Rx        01F5 -  8    E0 40 00 0F 20 00 01 D5
     6)         2.400 1  Rx        00F1 -  4    00 01 00 40
     7)         3.400 1  Rx        01E5 -  8    46 07 58 C0 05 F8 A6 00
     8)         3.600 1  Rx        0232 -  7    9F FF A0 00 03 12 00
     9)         4.800 1  Rx        01E1 -  3    00 FE 02
    10)         6.000 1  Rx        0320 -  8    E0 00 00 00 00 00 00 00
    11)         7.500 1  Rx        01F1 -  8    8E 12 00 00 08 00 30 72
    12)         7.900 1  Rx        00C9 -  8    84 0F F2 13 54 10 00 00
    13)         8.100 1  Rx        00F9 -  8    00 00 00 00 00 00 00 00
    14)         8.300 1  Rx        00C1 -  8    F3 92 BE F0 F0 01 CE 16
    15)         8.600 1  Rx        00C5 -  8    F0 2B A5 0D B0 36 D1 3B
    16)         8.800 1  Rx        0185 -  2    03 FB
    17)         9.000 1  Rx        01C7 -  7    09 AE 76 51 03 FF 3E
    18)         9.900 1  Rx        0191 -  8    07 20 07 2D 07 20 75 40
    19)        10.000 1  Rx        01F3 -  3    C0 3C 00
    20)        12.400 1  Rx        00F1 -  4    1C 01 00 40
    21)        13.400 1  Rx        01E5 -  8    46 07 59 E0 05 F8 A4 00
    22)        13.700 1  Rx        01E9 -  8    00 08 00 0C 00 2E 00 00
    23)        13.900 1  Rx        0230 -  8    00 00 30 80 00 00 1F FD
    24)        14.900 1  Rx        03C9 -  8    07 66 00 00 00 00 00 00
    25)        16.400 1  Rx        03C1 -  8    07 65 F7 00 00 00 00 00
    26)        18.300 1  Rx        00C1 -  8    C3 92 BE F0 00 02 7F 2F
    27)        18.600 1  Rx        00C5 -  8    C0 2B A5 0D 80 36 D1 3B
    28)        19.900 1  Rx        00C9 -  8    84 10 60 16 48 10 00 00
    29)        20.100 1  Rx        00F9 -  8    00 00 00 00 00 00 00 00
    30)        21.900 1  Rx        0191 -  8    07 26 07 2D 07 26 59 42
    31)        22.400 1  Rx        00F1 -  4    28 01 00 40
    32)        23.300 1  Rx        01E5 -  8    46 07 5A 80 08 F8 A6 00
    33)        23.600 1  Rx        0232 -  7    AF FE A0 00 03 12 00
    34)        25.900 1  Rx        0216 -  2    00 FF
    35)        26.200 1  Rx        01A1 -  8    00 28 25 00 00 00 48 00
    36)        26.400 1  Rx        01C3 -  8    07 26 08 79 00 00 59 00
    37)        26.600 1  Rx        01C4 -  8    16 62 C2 57 00 00 00 00
    38)        26.800 1  Rx        01C5 -  8    2D C8 2B 20 2D DD 00 00
    39)        27.100 1  Rx        01F5 -  8    E0 40 00 0F 20 00 01 D4
    40)        27.400 1  Rx        0320 -  8    20 00 00 00 00 00 00 00
    41)        27.600 1  Rx        02C3 -  8    07 33 06 5C 00 00 00 00
    42)        27.800 1  Rx        02D1 -  8    00 00 00 00 00 00 00 00
    43)        28.300 1  Rx        00C1 -  8    D3 92 BE F0 10 02 7F 2F
    44)        28.600 1  Rx        00C5 -  8    D0 2B A5 0D 90 36 D1 3B
    45)        28.700 1  Rx        0185 -  2    03 F9
    46)        29.000 1  Rx        01C7 -  7    09 AE B6 50 03 FF 3E
    47)        31.900 1  Rx        00C9 -  8    84 10 C4 19 3C 10 00 00
    48)        32.200 1  Rx        00F9 -  8    00 00 00 00 00 00 00 00
    49)        32.400 1  Rx        00F1 -  4    34 01 00 40
    50)        33.300 1  Rx        01E5 -  8    46 07 5C A0 09 F8 A3 00
    51)        33.600 1  Rx        01E9 -  8    00 0C 00 0C 00 2E 00 00
    52)        33.900 1  Rx        0191 -  8    07 26 07 33 07 26 59 42
    53)        35.000 1  Rx        01E1 -  3    00 FD 03
    54)        37.400 1  Rx        01F3 -  3    00 7C 00
    55)        38.300 1  Rx        00C1 -  8    23 93 7F 72 20 02 7F 2F
    56)        38.600 1  Rx        00C5 -  8    E0 2B A5 0D A0 36 D1 3B
    57)        42.400 1  Rx        00F1 -  4    00 00 00 40
    58)        43.400 1  Rx        01E5 -  8    46 07 5D C0 0A F8 A1 00
    59)        43.600 1  Rx        0214 -  4    06 00 03 FD
    60)        43.900 1  Rx        00C9 -  8    84 11 26 1C 32 10 00 00
    61)        44.100 1  Rx        00F9 -  8    00 00 00 00 00 00 00 00
    62)        44.300 1  Rx        0232 -  7    BF FD A0 00 03 12 00
    63)        44.600 1  Rx        02F9 -  6    00 01 17 00 00 00
    64)        44.900 1  Rx        0348 -  4    00 62 00 6B
    65)        45.100 1  Rx        034A -  4    00 61 00 69
    66)        45.800 1  Rx        0191 -  8    07 2E 07 33 07 2E 40 45
    67)        46.100 1  Rx        0320 -  8    60 00 00 00 00 00 00 00
    68)        48.400 1  Rx        00C1 -  8    33 93 7F 72 30 02 7F 2F
    69)        48.700 1  Rx        00C5 -  8    30 2C 67 F5 F0 37 85 DB
    70)        48.800 1  Rx        0185 -  2    03 F9
    71)        49.000 1  Rx        01C7 -  7    09 AE F6 4F 03 FF 3E
    72)        51.000 1  Rx        01C5 -  8    2E 03 2B 1D 2E 06 00 00
    73)        51.300 1  Rx        01A1 -  8    00 28 25 00 00 00 2F 00
    74)        51.500 1  Rx        01C3 -  8    07 38 07 AE 00 00 40 00
    75)        51.800 1  Rx        01C4 -  8    19 62 C2 57 00 00 00 00
    76)        52.000 1  Rx        01F5 -  8    E0 40 00 0F 20 00 01 D1
    77)        52.400 1  Rx        00F1 -  4    1C 01 00 40
    78)        53.400 1  Rx        01E5 -  8    46 07 5F E0 0B F8 9E 00
    79)        53.600 1  Rx        01E9 -  8    00 0C 00 0C 00 2A 00 00
    80)        55.900 1  Rx        00C9 -  8    80 11 74 13 2F 10 00 00
    81)        56.100 1  Rx        00F9 -  8    00 00 00 00 00 00 00 00
    82)        57.800 1  Rx        0191 -  8    07 38 07 39 07 38 31 48
    83)        58.300 1  Rx        00C1 -  8    03 93 7F 72 40 03 31 69
    84)        58.500 1  Rx        00C5 -  8    00 2C 67 F5 C0 37 85 DB
    85)        62.400 1  Rx        00F1 -  4    28 01 00 40
    86)        63.300 1  Rx        01E5 -  8    46 07 61 80 09 F8 9F 00
    87)        63.500 1  Rx        0232 -  7    80 00 A0 00 03 12 00
    88)        63.800 1  Rx        0230 -  8    00 00 00 80 00 00 00 00
    89)        64.800 1  Rx        01E1 -  3    00 00 00
    90)        66.100 1  Rx        0320 -  8    A0 00 00 00 00 00 00 00
    91)        67.300 1  Rx        01F3 -  3    40 BC 00
    92)        67.800 1  Rx        00C9 -  8    80 11 C2 16 2F 10 00 00
    93)        68.100 1  Rx        00F9 -  8    00 00 00 00 00 00 00 00
    94)        68.300 1  Rx        00C1 -  8    13 93 7F 72 50 03 31 69
    95)        68.600 1  Rx        00C5 -  8    10 2C 67 F5 D0 37 85 DB
    96)        68.700 1  Rx        0185 -  2    03 FB
    97)        69.000 1  Rx        01C7 -  7    09 AE 36 52 03 FF 3E
    98)        69.900 1  Rx        0191 -  8    07 38 07 3F 07 38 31 48
    99)        72.300 1  Rx        00F1 -  4    34 01 00 40
   100)        73.400 1  Rx        01E5 -  8    46 07 63 A0 0E F8 9C 00
   101)        73.600 1  Rx        01E9 -  8    00 0C 00 0C 00 2D 00 00
   102)        76.000 1  Rx        01C5 -  8    2E 1C 2B 1D 2E 1D 00 00
   103)        76.300 1  Rx        01A1 -  8    00 28 25 00 00 00 2F 00
   104)        76.500 1  Rx        01C3 -  8    07 3F 07 A6 00 00 31 00
   105)        76.800 1  Rx        01C4 -  8    1C 62 C2 57 00 00 00 00
   106)        77.000 1  Rx        01F5 -  8    ED 40 00 0F 00 00 01 CD
   107)        77.500 1  Rx        02C3 -  8    07 45 06 5B 00 00 00 00
   108)        77.700 1  Rx        02D1 -  8    00 00 00 00 00 00 00 00
   109)        78.300 1  Rx        00C1 -  8    23 93 7F 72 60 03 31 69
   110)        78.600 1  Rx        00C5 -  8    20 2C 67 F5 E0 37 85 DB
   111)        79.900 1  Rx        00C9 -  8    80 12 18 19 31 10 00 00
   112)        80.100 1  Rx        00F9 -  8    00 00 00 00 00 00 00 00
   113)        81.800 1  Rx        0191 -  8    07 3F 07 45 07 3F 2F 4B
   114)        82.400 1  Rx        00F1 -  4    00 01 00 40
