PCAN USB Driver for Beagle Bone Black with Ubuntu
Naqqash
Post by Naqqash » Mon 3. Nov 2014, 17:49
I am trying to install the driver of the Peak PCAN USB for my Beagle Bone Black. I am running ubuntu 14.04 on the beagle bone black with kernel version 3.8.13.bone59.. here is the wiki
http://elinux.org/Beagleboard:Ubuntu_On ... Bone_Black
Thanks to Michael for referring me this post
http://www.peak-system.com/forum/viewto ... f=59&t=256
it helped a lot in installing the driver on my Ubuntu virtual machine and it is working. I mean the driver is successfully installed and I can see it is connected.
Now by using the same procedure I am trying to install the driver for my beagle bone. Initially it was giving me error that version.h file is missing. I found a post here
http://www.peak-system.com/forum/viewto ... bian#p1934
and I have updated the source file headers of beagle bone black. I have used these instruction from the developer may be useful for someone else
https://groups.google.com/forum/#!topic ... 5RLNUGYrAc
Now after updating the kernel header the version.h problem was solved. I again tried to follow the steps mentioned in the previous post for installing drivers for ubuntu but still not successful, see below for the response,
1) make clean
respone:
ubuntu@arm:~$ uname -r
3.8.13-bone59
ubuntu@arm:~$ cd peak-linux-driver-7.13
ubuntu@arm:~/peak-linux-driver-7.13$ make clean
make[1]: Entering directory `/home/ubuntu/peak-linux-driver-7.13/driver'
rm -f src/*o src/*~ src/.*cmd *o *ko *~ .*cmd pcan.mod.c
make[1]: Leaving directory `/home/ubuntu/peak-linux-driver-7.13/driver'
make[1]: Entering directory `/home/ubuntu/peak-linux-driver-7.13/lib'
rm -f src/*~ src/*.o *~ *.so.*
make[1]: Leaving directory `/home/ubuntu/peak-linux-driver-7.13/lib'
make[1]: Entering directory `/home/ubuntu/peak-linux-driver-7.13/test'
rm -f src/*~ src/*.o *~ receivetest transmitest bitratetest filtertest pcan-settings
make[1]: Leaving directory `/home/ubuntu/peak-linux-driver-7.13/test
So far its fine no version.h file problem as before,
2) make NET=NO
response:
ubuntu@arm:~/peak-linux-driver-7.13$ make NET=NO
make[1]: *** No rule to make target `depend'. Stop.
*** Host machine kernel version=3.8.13-bone59
*** Driver kernel version=3.8.13
*** Path to kernel sources=/lib/modules/3.8.13-bone59/build
*** use KBUILD=yes
make -C /lib/modules/3.8.13-bone59/build SUBDIRS=/home/ubuntu/peak-linux-driver-7.13/driver EXTRA_CFLAGS="-I/home/ubuntu/peak-linux-driver-7.13/driver -DNO_DEBUG -DMODVERSIONS -DPARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DDONGLE_SUPPORT -DPCCARD_SUPPORT -DNO -DNO_RT " V=0 modules
make[2]: Entering directory `/usr/src/linux-3.8.13-bone59'
CC [M] /home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_main.o
CC [M] /home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_fops.o
CC [M] /home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_fifo.o
CC [M] /home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_filter.o
CC [M] /home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_parse.o
CC [M] /home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_sja1000.o
CC [M] /home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_common.o
CC [M] /home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_pci.o
/home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_pci.c: In function ‘pcan_pci_probe’:
/home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_pci.c:610:2: error: implicit declaration of function ‘pcim_enable_device’ [-Werror=implicit-function-declaration]
err = pcim_enable_device(pciDev);
make[3]: *** [/home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_pci.o] Error 1
make[2]: *** [_module_/home/ubuntu/peak-linux-driver-7.13/driver] Error 2
make[2]: Leaving directory `/usr/src/linux-3.8.13-bone59'
make[1]: *** [all] Error 2
cc src/libpcan.c -fPIC -shared -O2 -Wall -Wl,-soname,libpcan.so.0 -lc -I. -I../driver -DNO_RT -o libpcan.so.0.6
cc src/receivetest.c src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o receivetest -lpcan -DNO_RT
cc src/transmitest.cpp src/common.c src/parser.cpp -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o transmitest -lpcan -lstdc++ -DNO_RT
cc src/bitratetest.c src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o bitratetest -lpcan -DNO_RT
cc src/filtertest.cpp src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o filtertest -lpcan -lstdc++ -DNO_RT
cc src/pcan-settings.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o pcan-settings -lpopt -g
make[1]: Leaving directory `/home/ubuntu/peak-linux-driver-7.13/test'
Now if I compare this with my Ubuntu virtual machine when I was installing, the response is not the same because I am having some errors hence can't create the .ko file for the driver and installer is giving an error that .ko file is missing.
I am not sure what to do about it now, any help in this regard will be highly appreciated. Please let me know if more information is required.
Naqqash
Re: PCAN USB Driver for Beagle Bone Black with Ubuntu
Post by M.Maidhof » Tue 4. Nov 2014, 10:32
your BeagleBone device has no PCI bus, so please build the driver without PCI. Best solution will be to build the driver for the PCAN-USB only (see RaspberryPI thread for the build options on such ARM devices):
make NET=NO PCI=NO PAR=NO ISA=NO PCC=NO DNG=NO
Naqqash
Post by Naqqash » Thu 6. Nov 2014, 12:57
Hi Michael,
I had some problem with the ubuntu version so I switched back to the Debain Wheezy and updated the source headers using the same process as I have mentioned above.
Thanks for the suggestion.
Below is the step by step commands and responses;
I have installed the libpopt.dev libarary and g++ before as suggested.
make clean
root@beaglebone:~/peak-linux-driver-7.13# make clean
make[1]: Entering directory `/root/peak-linux-driver-7.13/driver'
make[1]: Leaving directory `/root/peak-linux-driver-7.13/driver'
make[1]: Entering directory `/root/peak-linux-driver-7.13/lib'
make[1]: Leaving directory `/root/peak-linux-driver-7.13/lib'
make[1]: Entering directory `/root/peak-linux-driver-7.13/test'
make[1]: Leaving directory `/root/peak-linux-driver-7.13/test'
then
root@beaglebone:~/peak-linux-driver-7.13# make NET=NO PCI=NO PAR=NO ISA=NO PCC=NO DNG=NO
*** Host machine kernel version=3.8.13-bone50
*** Path to kernel sources=/lib/modules/3.8.13-bone50/build
*** use KBUILD=yes
make -C /lib/modules/3.8.13-bone50/build SUBDIRS=/root/peak-linux-driver-7.13/driver EXTRA_CFLAGS="-I/root/peak-linux-driver-7.13/driver -DNO_DEBUG -DMODVERSIONS -DNO -DUSB_SUPPORT -DNO -DNO_PCIEC_SUPPORT -DNO -DNO -DNO -DNO -DNO_RT " V=0 modules
make[2]: Entering directory `/usr/src/linux-3.8.13-bone50'
CC [M] /root/peak-linux-driver-7.13/driver/src/pcan_main.o
CC [M] /root/peak-linux-driver-7.13/driver/src/pcan_fops.o
CC [M] /root/peak-linux-driver-7.13/driver/src/pcan_fifo.o
CC [M] /root/peak-linux-driver-7.13/driver/src/pcan_filter.o
CC [M] /root/peak-linux-driver-7.13/driver/src/pcan_parse.o
CC [M] /root/peak-linux-driver-7.13/driver/src/pcan_sja1000.o
CC [M] /root/peak-linux-driver-7.13/driver/src/pcan_common.o
CC [M] /root/peak-linux-driver-7.13/driver/src/pcan_usb_core.o
CC [M] /root/peak-linux-driver-7.13/driver/src/pcan_usb.o
CC [M] /root/peak-linux-driver-7.13/driver/src/pcan_usbpro.o
CC [M] /root/peak-linux-driver-7.13/driver/src/pcan_timing.o
LD [M] /root/peak-linux-driver-7.13/driver/pcan.o
Building modules, stage 2.
MODPOST 1 modules
CC /root/peak-linux-driver-7.13/driver/pcan.mod.o
LD [M] /root/peak-linux-driver-7.13/driver/pcan.ko
make[2]: Leaving directory `/usr/src/linux-3.8.13-bone50'
then
sudo make install
root@beaglebone:~/peak-linux-driver-7.13# sudo make install
mkdir -p /usr/lib
cp libpcan.so.0.6 /usr/lib/libpcan.so.0.6
ln -sf /usr/lib/libpcan.so.0.6 /usr/lib/libpcan.so.0
ln -sf /usr/lib/libpcan.so.0 /usr/lib/libpcan.so
mkdir -p /usr/include
cp libpcan.h /usr/include/libpcan.h
chmod 644 /usr/include/libpcan.h
/sbin/ldconfig
cp receivetest /usr/local/bin
cp transmitest /usr/local/bin
cp bitratetest /usr/local/bin
cp filtertest /usr/local/bin
cp pcan-settings /usr/local/bin
sudo insmod pcan.ko
and then cat /proc/pcan
root@beaglebone:~/peak-linux-driver-7.13/driver# cat /proc/pcan
*------------- Release_20141017_n (7.13.0) Nov 6 2014 11:45:15 --------------
*------------------------------- [mod] [usb] --------------------------------
*--------------------- 1 interfaces @ major 240 found -----------------------
32 usb -NA- ffffffff 255 0x001c 00000000 00000000 00000000 00000000 0x0000
Thank you very much again Michael for your help.
I hope this post will be useful for anybody working on BBB with Debain or Ubuntu. Don't forget to connect the power cable to your BBB when you will connect the PCAN USB. If driver will not detect the PCAN USB after installing, try rebooting the system.
Naqqash
Naqqash
Naqqash
Post by Naqqash » Thu 6. Nov 2014, 13:08
Problem solved see the above post.
