Dann schreibt er die Datenbytes in die Excel Zelle.
#If VBA7 And Win64 Then
' 64 bit Excel
Public Declare PtrSafe Sub Sleep Lib "kernel32" ( _
ByVal dwMilliseconds As LongLong)
#Else
' 32 bit Excel
Public Declare Sub Sleep Lib "kernel32" ( _
ByVal dwMilliseconds As Long)
#End If
' the CAN Types
Dim myMsgRecv As TPCANMsg
Dim myMsgSend As TPCANMsg
Dim myTimeStamp As TPCANTimestamp
Sub WaitForCANID()
Sheets("Tabelle1").Activate ' select first Sheet
Range("A1").Select ' set cursor to A1
ActiveCell().Value = "CAN-Data"
' now Init CAN-USB Channel one with 500K
ret = CAN_Initialize(PCAN_USBBUS1, PCAN_BAUD_500K)
If ret = PCAN_ERROR_OK Then ' CAN Init OK?
MsgBox "CAN Bus OK!", vbInformation ' show MsgBox if OK
ret = CAN_Read(PCAN_USBBUS1, myMsgRecv, myTimeStamp) ' read from driver
While (ret = PCAN_ERROR_OK) Or (ret = PCAN_ERROR_QRCVEMPTY) ' read as long a Msg available or queu empty
' if a CAN Message was reveived - we send out the CAN-ID+1 DLC1 with 0xFF as dataByte 1 for Test
If ret = PCAN_ERROR_OK Then ' Msg received
myMsgSend.ID = myMsgRecv.ID + 1
myMsgSend.LEN = 1
myMsgSend.DATA(0) = &HFF
ret = CAN_Write(PCAN_USBBUS1, myMsgSend)
If myMsgRecv.MsgType = PCAN_MESSAGE_STANDARD Then ' Msg is 11Bit type
If myMsgRecv.ID = &H100 Then ' ID of the Message must be 0x100 (HEX)
' we put the values in the first sheet in Cell A2 to A11
ActiveCell(2, 1).Value = myMsgRecv.ID
ActiveCell(3, 1).Value = myMsgRecv.LEN
For a = 0 To myMsgRecv.LEN - 1
ActiveCell(4 + a).Value = myMsgRecv.DATA(a)
Next
CAN_Uninitialize (PCAN_USBBUS1) ' deinit the CAN
Exit Sub ' end leave the sub
End If
End If
End If
Sleep (50) ' 50ms sleep and read again:
Wend
Else
MsgBox "Error while init CAN Bus", vbCritical
End If
End Sub
