PCAN-View Ring buffer
Racailloux
Post by Racailloux » Fri 28. Nov 2014, 09:29
I am using PCAN-View with PCAN-USB and when I select the ring buffer, this stops at 100.000 datagram recorded and don't ring over the oldest datagram.
I updated to the latest version of PCAN-View and I am under Win7 x64.
-Dead Picture link removed by Admin-
the behavior between Linear and ring buffering is the same. Any suggestion?
Racailloux
Re: PCAN-View Ring buffer
Post by Racailloux » Fri 28. Nov 2014, 09:31
Sorry, I missed the good section for the topic.
Post by M.Maidhof » Fri 28. Nov 2014, 10:52
when you use linear buffer, the traces stops after 100000 messages, when you use ring buffering, the tracer will work normally until 100% buffer fill size, than it will remove the older messages, and will keep the newest messages only. This is working here with the same PCAN-View version without problems, maybe you think it will not work due to the fact that the RX/TX counter will not rise up anymore after 100% buffer fill size was reached, but you should see that the recording time will still rise up.
Racailloux
Post by Racailloux » Sat 29. Nov 2014, 10:26
Thanks for the fast answer.
Actually, whatever I use the ring or linear buffer, the new datagrams are not received after 100% of buffer is reach. The oldest are not replaced by latest one in ring mode. That is the problem I got.
Rac'
Post by M.Maidhof » Mon 1. Dec 2014, 11:49
does the recording time rise up after the buffer is full in ring buffer mode? Please post some screenshots of the PCAN-View showing the problem, or contact us by phone, to check your system. It is working here without problems on our system.
