Simple Python Program using PCAN API
Locked
jalcock501
Post by jalcock501 » Thu 5. Feb 2015, 12:06
I need help starting a simple Python PCAN program on Linux that can print out the messages received from the PCAN-USB device, unfortunately I am struggling to understand how to use the API.
Could someone please advise me how to do this, any examples would be greatly appreciated.
Jim
Re: Simple Python Program using PCAN API
Post by PEAK-Support » Thu 5. Feb 2015, 13:23
compile the driver in CharDev Mode, and run our Python samples. Very easy...
Here a complete HowTo for getting thinks work:
CAN CharDev Driver, PCANBasic for Linux, Samples for PCAN-Basic for LINUX (Python, Java, C++)
HowTo...
 Download and Install the PEAK-System LINUX CAN Driver as CharDev Device and runn all included samples
What to do up in front:
* Be sure you have root previleges to install the driver and copy the libs
* Be sure you have update your system (apt-get update)
* Be sure you have basic LINUX knwoledge
Login to your system
Go to your home directory
Create a directory for the files (for example PEAK-Linux) by call
$ mkdir PEAK-Linux
$ cd PEAK-Linux
Download the PCAN-Linux PDF manual (and also read it!)
wget http://www.peak-system.com/produktcd/Develop/PC%20interfaces/Linux/PCAN-Linux%20Driver/PCAN-Driver_for_Linux_eng.pdf
Step1 - download and install the driver
Download the PEAK-Linux driver package
(Take care to use the latest Version - so replace the x with the current version example: peak-linux-driver-7.9.tar.gz)
$ wget http://www.peak-system.com/produktcd/Develop/PC%20interfaces/Linux/PCAN-Linux%20Driver/peak-linux-driver-x.x.tar.gz
Unpack packages
$ tar -xzf peak-linux-driver-x.x.tar.gz
Change to the driver directory
$ cd peak-linux-driver-7.9
Call make with your needed settings
For example build for CharDev (NET=NO) and without ISA/Dongle/PCI and PC Card Support - only USB
$ make all NET=NO PCI=NO ISA=NO DNG=NO PCC=NO
When you get the error "popt.h not found", please call
$ sudo apt-get install libpopt-dev
and call the make again
After that install the driver and lib by calling
$ sudo make install
and
$ modprobe pcan
Check if the driver is installed, and if your interface is connected (be sure your USB CAN Interface is plugged in!)
$ cat /proc/pcan
$ *------------- PEAK-System CAN interfaces (www.peak-system.com) -------------
$ *------------- Release_20130814_n (7.9.0) Jan  9 2014 11:17:31 --------------
$ *---------------------------- [mod] [par] [usb] -----------------------------
$ *--------------------- 2 interfaces @ major 251 found -----------------------
$ *n -type- ndev --base-- irq --btr- --read-- --write- --irqs-- -errors- status
$ 32    usb -NA- 00000002 001 0x001c 00000000 00000000 00000000 00000000 0x0000
$ 33    usb -NA- 00000007 017 0x001c 00000000 00000000 00000000 00000000 0x0000
You see 2 installed PCAN-USB on the CharDev driver running on a Baud rate of 500K (BTR0/BTR1 001C)
Run receivetest
$ /usr/local/bin/receivetest
$ receivetest Version "Release_20090203_n"  (www.peak-system.com)
$ ------- Copyright (C) 2004-2009 PEAK System-Technik GmbH ------
$ receivetest comes with ABSOLUTELY NO WARRANTY.     This is free
$ software  and you are welcome  to redistribute it under certain
$ conditions.   For   details   see    attached   COPYING   file.
$ receivetest: device node="/dev/pcan0"
$              Only standard frames are accepted, init with 500 kbit/sec.
$ receivetest: driver version = Release_20130814_n
$ 190860.244 receivetest: m s 0x00000032 7 02 02 00 30 04 00 00
$ 206244.650 receivetest: m s 0x00000123 3 12 23 45
$ 207724.714 receivetest: m s 0x00000032 7 02 02 00 30 04 00 00
$ 208316.671 receivetest: m s 0x00000123 3 12 23 45
$ 217556.948 receivetest: m s 0x00000456 3 03 02 01
$ 219700.948 receivetest: m s 0x00000032 7 02 02 00 30 04 00 00$
Step2 - download and install the PCAN-Basic for Linux (skip if you do not want to use API)
Download the PEAK-Linux PCAN-Basic package (be sure you are in the directory you created for the PEAK stuff!)
Always use the latest Version - so replace the x with the current version example: PCAN_Basic_Linux-2.0.2tar.gz
$ wget http://www.peak-system.com/produktcd/Develop/PC%20interfaces/Linux/PCAN-Basic_API_for_Linux/PCAN_Basic_Linux-x.x.xtar.gz
Unpack packages
$ tar -xzf PCAN_Basic_Linux-x.x.x.tar.gz
Change to the unpacked files and the LIB directory
$ cd PCAN_Basic_Linux-2.0.2/pcanbasic
Call make
$ make all
After that install the lib by calling
$ sudo make install
Compile the c++ /phyton sample
$ cd sample
$ make all
and run a simple receive test
$ cd c++
$ ./pcaneventread
Initialize CAN: 0
  - R ID: 123 LEN:3 DATA:12 23 45 00 00 00 00 00
  - R ID: 456 LEN:3 DATA:03 02 01 00 00 00 00 00
  - R ID:  32 LEN:7 DATA:02 02 00 30 04 00 00 00
To run the Python sample you need the Tkinter package
$ apt-get install python-tk
and the Tix
$ apt-get install Tix (TK extension library)
then run the sample (need GUI/X-Windows)
$ python PCANBasicExample.pyw
Step 3 - compile and run sample code
After a successful compiling and installing the PEAK CharDev Linux drivers and the PCAN-Basic Linux lib,
on a DEBIAN based Distribution (Ubuntu, MintOS etc.), you could compile and run samples with graphical Interface.
For that you need to install the following packages.
If you are not sure what you are doing - stop here - use Google and read manuals.
We could no support by setup your Environment - if you have any problem to get this things work on you System, please ask the community / read more manual.
I.)
Install Basic Development Environment- follow this instruction:
https://wiki.gnome.org/DeveloperTools/Installation/Ubuntu
$ sudo apt-get install g++
If you want to use our PCAN-View for Linux example you need the GTK+2:
$ sudo apt-get install gtk+2.0
$ wget http://www.peak-system.com/cupd2/PCAN-View-LINUX-GTK+.tar.gz
NOTICE - this download link will no longer available - ask for this file at support@peak-system.com
$ tar -xzf PCAN-View-LINUX-GTK+.tar.gz
$ cd pcanview
$ make all
and run the tool (need GUI/X-Windows)
$ ./pcanview
II.)
Recommended Development Tools (incl GTK+ Development)
anjuta - Integrated development environment (or use your favorite IDE or text editor)
glade - Interface designer
devhelp - API Browser
$ sudo apt-get install anjuta glade devhelp
For Phyton:
$ sudo apt-get install python python-gobject
If you want to use the newer GTK+3 download these packages
$ sudo apt-get install gstreamer0.10-plugins-bad gstreamer0.10-plugins-bad-multiverse
$ sudo apt-get install libgtk-3-doc gstreamer0.10-doc libclutter-1.0-doc libgda-5.0-doc
$ sudo apt-get install libgtk-3-dev libgstreamer0.10-dev libclutter-1.0-dev libwebkitgtk-3.0-dev libgda-5.0-dev
$ sudo apt-get install libgtkmm-3.0-dev libgstreamermm-0.10-dev libgdamm5.0-dev
Docu:
$ sudo apt-get install libgtkmm-3.0-doc libgstreamermm-0.10-doc libgdamm5.0-doc
III.)
For Java Development:
Install JAVA JDK/JRE
(see http://www.webupd8.org/2012/01/install-oracle-java-jdk-7-in-ubuntu-via.html)
sudo add-apt-repository ppa:webupd8team/java
sudo apt-get update
sudo apt-get install oracle-java7-installer
IV.)
To automatically set up the Java 7 environment variables, you can install the following package:
sudo apt-get install oracle-java7-set-default
V.)
To Edit the Java sample incl. graphical Interface
Install NetBeans 7.x or eclipse
Before you could use the PCAN-Basic for JAVA Interface you need to compile and install the JNI first (Java Native Interface)
The source could be found in the PCAN_Basic_Linux package in the Subdirectory pcanjni
!Please check if the Java Version you use fit to the project settings!
Change in the make file the JAVA_HOME to your installed environment
For example:
JAVA_HOME = /usr/lib/jvm/java-7-oracle
After that call
$ make all
$ make install
to build and install the JNI Lib
VI.)
To remove the JAVA JDK7
$ sudo apt-get remove oracle-java7-installer
camiiiille
Post by camiiiille » Thu 6. Jul 2017, 15:40
I am interrested in step3 but there is an error message when I run "make all" in pcanview.
The error is :
Makefile:104: recipe for target 'pcanview' failed
make:*** [pcanview] Error 1
Could you help me?
Camille
Post by PEAK-Support » Thu 6. Jul 2017, 15:48
Your error looks like you have no root previlege. See "What to do up in front:"
go to the tutorial step by step
camiiiille
Post by camiiiille » Thu 6. Jul 2017, 16:36
U.Wilhelm wrote:Your error looks like you have no root previlege. See "What to do up in front:"
To have the root privilege, I just need to write "sudo make all", don't I?
Concerning the "what to do" part, I think I forget anything and for the step by step I tried twice.
The exact error is :
pi@raspberrypi:~/Desktop/pcanview $ make all
g++ src/EventHandler.cpp src/Message.cpp src/PCanView.cpp src/Process.cpp src/ReceiveMessage.cpp src/ReceiveMessages.cpp src/TraceMessage.cpp src/TraceMessages.cpp src/TransmitMessage.cpp  src/TransmitMessages.cpp  -g  -I. -I../..  -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o pcanview   -lpcanbasic -lrt -DNO_RT $(pkg-config --cflags --libs gtk+-2.0 gmodule-2.0) -g
In file included from /usr/include/PCANBasic.h:25:0,
                 from src/PCanView.h:46,
                 from src/EventHandler.cpp:19:
/usr/include/pcan.h:47:2: error: #error "double define for DWORD, WORD, BYTE found"
                 from src/Message.cpp:19:
                 from src/PCanView.cpp:20:
                 from src/Process.cpp:20:
                 from src/ReceiveMessage.cpp:20:
                 from src/ReceiveMessages.cpp:19:
                 from src/TraceMessage.cpp:19:
                 from src/TraceMessages.cpp:19:
                 from src/TransmitMessage.cpp:19:
                 from src/TransmitMessages.cpp:19:
make: *** [pcanview] Error 1
Is it due to the directory? Is it inside the PCANBasic file? The compilation?
zhangjk
Post by zhangjk » Fri 10. Apr 2020, 07:32
did you solve the problem?
Post by PEAK-Support » Mon 13. Apr 2020, 12:51
Yes - user error - so thread is closed (2017)
Locked
