PCAN-view and PCAN-USB
hicham
Post by hicham » Wed 11. Mar 2015, 15:03
I have added 3 CAN messages in the transmit part of the PCAN-VIEW like the following picture
I use PCAN-USB device to output can messages
but in my receiver device I only receive the first message.
When checking the trace tab, I find all the messages
My end device is a custom board with custom firmware, and it works just find when I plug it in real CAN network.
How can I investigate this problem ?
Thank you
Re: PCAN-view and PCAN-USB
Post by M.Maidhof » Wed 11. Mar 2015, 16:25
PCAN-View shows a BUSHEAVY status, so it looks like your deviced does not acknoweldge the message, and the CAN-Controller in PCAN-View will resend the same messages all the time. You need at least two working (active) CAN nodes on a CAN system. Please switch your device to acknoweldge mode instead of silent or listen only.
hicham
Post by hicham » Fri 13. Mar 2015, 14:21
Thank you for the help, problem resolved
