I am using PEAK USB controller on ubuntu 14.04 LTS. Note: I do use the USB controller on a USB 3.0 port. According the documentation it should be compatible.
I have installed peak linux driver 7.14 with netdev support:
*------------- Release_20141219_n (7.14.0) Mar 9 2015 22:48:38 --------------
*------------------------- [mod] [par] [usb] [net] --------------------------
*--------------------- 1 interfaces @ major 250 found -----------------------
32 usb can0 ffffffff 003 0x001c 0000044d 00000000 0000048b 0000044d 0x000c
On PCAN View for windows everything works as a charm.
As soon as I start sending frames on linux with the SocketCAN API everything seems to work with simple candump:
candump can0
can0 601 [8] 2B 40 60 00 0F 00 00 00
can0 581 [8] 60 40 60 00 0F 00 00 00
candump any,0:0,#FFFFFFFF
can0 20000004 [8] 00 04 00 00 00 00 00 00 ERRORFRAME
can0 602 [8] 2B 40 60 00 0F 00 00 00
can0 582 [8] 60 40 60 00 0F 00 00 00
can0 601 [8] 2F 60 60 00 01 00 00 00
can0 581 [8] 60 60 60 00 01 00 00 00
can0 602 [8] 2F 60 60 00 01 00 00 00
can0 582 [8] 60 60 60 00 01 00 00 00
can0 601 [8] 23 7A 60 00 0F 00 00 00
can0 581 [8] 60 7A 60 00 0F 00 00 00
can0 602 [8] 23 7A 60 00 0F 00 00 00
Question: do I have a problem with my physical bus (I know 100 ohm resistant cable should actually be 120 ohm), my driver, or any other problem?
Thank you for your help and support!
