Hi
when I want write a message on can, I got this error.
Type could not be marshaled because the length of an embedded array instance does not match the declared length in the layout
Please help me about it.
Error on write
Re: Error on write
Please use the samples on the CD/DVD , they are tested and work fine (looks like you use a .NET Code)
Be sure you have copy the correct DLLs to your System32 and SysWow64 directory.
More info could be found here
