Recievetest doesn't return any data
hediented
Post by hediented » Mon 29. Jun 2015, 17:02
i have installed drivers for PCAN-USB. When i run cat /proc/pcan . I get the following:
*------------- Release_20141219_n (7.14.0) Jun 29 2015 16:30:06 --------------
*---------------- [mod] [isa] [pci] [dng] [par] [usb] [pcc] -----------------
*--------------------- 1 interfaces @ major 249 found -----------------------
32    usb   -NA- ffffffff 255 0x001c 00000000 00000000 00000186 00000000 0x0004
When i run ./receivetest -f=/dev/pcan32 i get:
receivetest Version "Release_20090203_n"  (www.peak-system.com)
receivetest comes with ABSOLUTELY NO WARRANTY.     This is free
receivetest: device node="/dev/pcan32"
             Only standard frames are accepted, init with 500 kbit/sec.
receivetest: driver version = Release_20141219_n
at this point i'm stuck and don't get any data. but if i close it (ctrl+c) i get:
receivetest: type            = usb
             Serial Number   = 0xffffffff
             Device Number   = 255
             count of reads  = 0
             count of writes = 0
             count of errors = 0
             count of irqs   = 442
             last CAN status = 0x0024
             last error      = 0
             open paths      = 1
receivetest: finished (0).
I am new at this so I would really appriciate any advice on how to continous data.
Re: Recievetest doesn't return any data
Post by M.Maidhof » Thu 2. Jul 2015, 15:30
do you use a terminated CAN cable and do you have another CAN transmitter with 500k baudrate connected to PCAN-USB?
hediented
Post by hediented » Thu 2. Jul 2015, 16:54
I have another CAN transmitter connected to it.
Thank you for fast reply.
Post by M.Maidhof » Thu 2. Jul 2015, 17:13
how about used baudrate of your transmitter and CAN cables (120 Ohm termination included on both sides)?
To help you with your problem we need full details, and all questions must be answered, otherwise we can´t support you with your problem.
