PCAN driver rx issue on linux [ ubuntu 14.04]
parai
Post by parai » Fri 13. Nov 2015, 09:49
Hello:
I have built and installed the pcan linux driver with version 7.15.2, I can use the pcanbasic library to transmit messages but I can't receive any message by the API Can_Read.
so can you tell me what's wrong and how to fix?
Re: PCAN driver rx issue on linux [ ubuntu 14.04]
Post by M.Maidhof » Fri 13. Nov 2015, 11:06
please post the output of cat /proc/pcan
could be a typical chardev/netdev issue like:
http://www.peak-system.com/forum/viewto ... rdev#p4092
or
http://www.peak-system.com/forum/viewto ... rdev#p3270
PCANBasic will only work on a chardev driver.
parai
Post by parai » Mon 16. Nov 2015, 02:33
Here is the cat /proc/pcan result
*------------- Release_20150729_n (7.15.2) Nov 13 2015 16:22:52 --------------
*---------- [mod] [isa] [pci] [pec] [dng] [par] [usb] [pcc] [net] -----------
*--------------------- 1 interfaces @ major 248 found -----------------------
32 usb can0 ffffffff 255 0x001c 00000000 00000000 00000000 00000000 0x0000
so according to your reply, should I build the driver as chardev? or there is other way to fix this issue, can you give any sample code use the netdev to send and receive message?
Post by M.Maidhof » Mon 16. Nov 2015, 10:38
PCANBasic API will only work with the chardev driver. When you want to work with the NetDev/SocketCAN driver, you can use the can-utils tools.
See:
http://www.peak-system.com/forum/viewto ... t=256#p723
http://www.peak-system.com/forum/viewto ... 3673#p3673
