I can see the information in symbols only in Receive/Transmit window. The trace files are purely hex based. Is there a way to see the information stored in symbols in the trace file? DO you have samples on how to go about this?
Impose Symbol Information on Trace File
Re: Impose Symbol Information on Trace File
Simply move, inside the Tracer Window, the mouse cursor over the Databytes you want to see in Signal based Format.
You also could select the trace, and use the "export Trace Data" Option to save the signal values in CSV or Text Base Format. More Info could be found in the Online Help - press F1 to open...
