is the current PCAN-USB Pro FD, support the LIN version J2602, if so how to configure the delivered c# sample to recognise this version.
Because in other products we configure first the LIN version after that we initialize device/Connect/Send...
Many thanks !
LIN version J2602
Re: LIN version J2602
The J2602 protocol is just a protocol based on LIN 2.0. The SAE J2602 LIN specification is more restrictive compared to the LIN 2.x specification:
- the baud rate is limited to 10.417Kbps
- slave-to-slave communication is not allowed
- event triggered frames are not allowed
So you can configure the frames as they are defined in the ldf, you have to use LIN 2.0 checksum for the used frames.
