I need to start the PCAN-miniPCIe on Xenomai. So I install the Xenomai-2.6.5(under the Linux Kernel-3.18.20),
and enable 'RT-Socket-CAN','Philips SJA1000 CAN controller','PEAK PCI Card'.
But without success.
Who can give me some helps?
Thanks.
dmesg
[ 6.445321] ledtrig-cpu: registered to indicate activity on CPUs
[ 6.445564] RT-Socket-CAN 0.90.2 - (C) 2006 RT-Socket-CAN Development Team
[ 6.445584] RTCAN SJA1000 driver initialized
[ 6.445613] PEAK-PCI-CAN: initializing device 001c:0008
[ 6.450708] PEAK-PCI-CAN: base_addr=f8068000 conf_addr=f805e000 irq=18
[ 6.450733] rtcan: registered rtcan0
[ 6.450748] PEAK-PCI-CAN: base_addr=f806a400 conf_addr=f805e000 irq=18
[ 6.450760] ERROR -16: IRQ 18 is busy, check shared interrupt support!
[ 6.450770] ERROR -16 while trying to register SJA1000 device!
[ 6.450782] Removing PEAK-PCI SJA1000 device rtcan0
[ 6.450786] Unregistering SJA1000 device rtcan0
[ 6.450797] RTCAN: unregistered rtcan0
[ 6.450813] PEAK-PCI-CAN: probe of 0000:07:00.0 failed with error -16
[ 6.450845] ERROR! No devices specified! Use mem=<port1>[,...] irq=<irq1>[,...]
[ 6.451003] TCP: cubic registered
[ 6.451310] NET: Registered protocol family 10
[ 6.451761] NET: Registered protocol family 17
[ 6.451783] Key type dns_resolver registered
cat /proc/interrupts
CPU0 CPU1
0: 42 0 IO-APIC-edge timer
1: 537 111 IO-APIC-edge i8042
3: 2 2 IO-APIC-edge
4: 2 2 IO-APIC-edge
8: 0 1 IO-APIC-edge rtc0
9: 2 1 IO-APIC-fasteoi acpi
12: 3 1 IO-APIC-edge i8042
14: 5713 3980 IO-APIC-edge ata_piix
15: 0 0 IO-APIC-edge ata_piix
19: 6997 118 IO-APIC 19-fasteoi ata_piix, ath9k
24: 0 0 PCI-MSI-edge PCIe PME
25: 0 0 PCI-MSI-edge PCIe PME
26: 0 0 PCI-MSI-edge PCIe PME
27: 0 0 PCI-MSI-edge PCIe PME
28: 0 0 PCI-MSI-edge PCIe PME
48: 62 656 PCI-MSI-edge eth0
49: 1470 702 PCI-MSI-edge i915
NMI: 16 15 Non-maskable interrupts
LOC: 16336 17709 Local timer interrupts
SPU: 0 0 Spurious interrupts
PMI: 16 15 Performance monitoring interrupts
IWI: 0 0 IRQ work interrupts
RTR: 0 0 APIC ICR read retries
RES: 2121 2233 Rescheduling interrupts
CAL: 356 174 Function call interrupts
TLB: 328 343 TLB shootdowns
TRM: 0 0 Thermal event interrupts
THR: 0 0 Threshold APIC interrupts
MCE: 0 0 Machine check exceptions
MCP: 2 2 Machine check polls
HYP: 0 0 Hypervisor callback interrupts
ERR: 0
MIS: 0
Driver can not to run on Xenomai
Re: Driver can not to run on Xenomai
Today, I update the Xenomai to Xenomai-3.0.2.but still no success.
I can see the two rtcan.
geng@geng-G-Series-CPU:~$ cat /proc/rtcan/devices
Name___________ _Baudrate State___ TX_Counter RX_Counter ____Errors
rtcan0 undefined stopped 0 0 0
rtcan1 undefined stopped 0 0 0
And start the rtcan.
geng@geng-G-Series-CPU:~$ sudo /usr/xenomai/sbin/rtcanconfig rtcan0 -b 1000000 -c none start -v
geng@geng-G-Series-CPU:~$ sudo /usr/xenomai/sbin/rtcanconfig rtcan1 -b 1000000 -c none start -v
rtcan0 1000000 active 0 0 0
rtcan1 1000000 active 0 0 0
Used the rtcan0 to receive,and rtcan1 to send,but no success.(Correct cable connection)
cd /usr/src/xenomai-3.0.2/utils/can
sudo ./rtcanrecv rtcan0 (The program has been waiting for data)
geng@geng-G-Series-CPU:/usr/src/xenomai-3.0.2/utils/can$ sudo ./rtcansend rtcan1 0x1 0x2 0x3 0x4 0x5 0x6 0x7 0x8 -v
interface rtcan1
s=3, ifr_name=rtcan1
<0x001> [8] 01 02 03 04 05 06 07 08
Cleaning up...
geng@geng-G-Series-CPU:/usr/src/xenomai-3.0.2/utils/can$ cat /proc/rtcan/devices
rtcan1 1000000 active 1 0 0
geng@geng-G-Series-CPU:/usr/src/xenomai-3.0.2/utils/can$ cat /proc/rtcan/sockets
Name___________ Filter ErrMask RX_Timeout_ns TX_Timeout_ns RX_BufFull TX_Lo
rtcan0 1 0x00000 infinite infinite 0 0
I suspect that the IRQ maybe have a problem.
geng@geng-G-Series-CPU:/usr/src/xenomai-3.0.2/utils/can$ cat /proc/interrupts
CPU0 CPU1
1: 4 697 IO-APIC-edge i8042
8: 1 0 IO-APIC-edge rtc0
12: 1 3 IO-APIC-edge i8042
14: 0 0 IO-APIC-edge ata_piix
15: 5162 5287 IO-APIC-edge ata_piix
16: 0 0 IO-APIC 16-fasteoi uhci_hcd:usb3
18: 0 1 IO-APIC 18-fasteoi ehci_hcd:usb1, uhci_hcd:usb8
19: 2420 71 IO-APIC 19-fasteoi ata_piix, uhci_hcd:usb5, uhci_hcd:usb7, ath9k
21: 140 350 IO-APIC 21-fasteoi uhci_hcd:usb4
23: 275 106 IO-APIC 23-fasteoi ehci_hcd:usb2, uhci_hcd:usb6
48: 63 287 PCI-MSI-edge eth2
49: 2749 62 PCI-MSI-edge i915
NMI: 27 20 Non-maskable interrupts
LOC: 17298 18108 Local timer interrupts
PMI: 27 20 Performance monitoring interrupts
RES: 2683 2948 Rescheduling interrupts
CAL: 171 275 Function call interrupts
TLB: 367 303 TLB shootdowns
MCP: 1 1 Machine check polls
ERR: 0
MIS: 0
dmes
[ 6.347583] RT-Socket-CAN 0.90.2 - (C) 2006 RT-Socket-CAN Development Team
[ 6.347645] RTCAN SJA1000 driver initialized
[ 6.347677] PEAK-PCI-CAN: initializing device 001c:0008
[ 6.352763] PEAK-PCI-CAN: base_addr=f80c0000 conf_addr=f80be000 irq=18
[ 6.352790] rtcan: registered rtcan0
[ 6.352803] PEAK-PCI-CAN: base_addr=f80c2400 conf_addr=f80be000 irq=18
[ 6.352824] rtcan: registered rtcan1
[ 6.352997] TCP: cubic registered
[ 6.353307] NET: Registered protocol family 10
[ 6.353775] NET: Registered protocol family 17
[ 6.353798] Key type dns_resolver registered
[ 6.354292] Using IPI No-Shortcut mode
[ 6.354615] Loading compiled-in X.509 certificates
[ 6.362256] Loaded X.509 cert 'Magrathea: Glacier signing key: 1902c21dd67788adf038483cd15f40ce2ef0a8fb'
[ 6.362287] registered taskstats version 1
[ 6.366200] Key type trusted registered
[ 6.372113] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[ 6.373534] Key type encrypted registered
[ 6.373547] AppArmor: AppArmor sha1 policy hashing enabled
[ 6.373552] evm: HMAC attrs: 0x1
[ 6.375004] Magic number: 12:186:539
[ 6.375041] tty ttyS19: hash matches
[ 6.375144] rtc_cmos 00:01: setting system clock to 2016-08-28 15:32:57 UTC (1472398377)
[ 6.375236] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 6.375239] EDD information not available.
[ 6.375392] PM: Hibernation image not present or could not be loaded.
[ 6.630893] ata1: SATA link down (SStatus 0 SControl 300)
[ 6.634817] ata3: SATA link down (SStatus 0 SControl 300)
[ 6.634849] usb 1-4: new high-speed USB device number 2 using ehci-pci
[ 6.649133] ata4: SATA link down (SStatus 0 SControl 300)
[ 6.649398] [Xenomai] xnintr_vec_handler: IRQ18 not handled. Disabling IRQ line
[ 6.704026] usb 2-4: new high-speed USB device number 3 using ehci-pci
interface rtcan1
Cleaning up...
CPU0 CPU1
ERR: 0
MIS: 0
dmes
at the moment we support XENOMAI 2.x only
But it looks that you need to change your BIOS settings, to be sure taht the CAN Crad use a own IRQ, not a shared one.
PCI devices are required to share interrupts.U.Wilhelm wrote:at the moment we support XENOMAI 2.x only
So,there is no BIOS setting to change this, nor would one be feasible, especially a Mini-PCIe card which is behind several PCI bridges.
View interrupts usage:
Then I disable the USB in the BIOS,the RTCAN receive/send has succeeded.
But all the USB is disable,does have other solutions?
You need to enable CONFIG_XENO_OPT_SHIRQ if you want your RTDM drivers to share IRQs.PCI devices are required to share interrupts.
Please also read here But this have nothing to do with our CAN Hardware. And why sould a Device behind a PCI bridge not use a own INT?
Have a good news, I adjust the CAN board position,keep it have a own IRQ ,it can work properly.U.Wilhelm wrote:You need to enable CONFIG_XENO_OPT_SHIRQ if you want your RTDM drivers to share IRQs.PCI devices are required to share interrupts.
Pleasealso read here But this have nothing to do with our CAN Hardware. And why sould a Device behind a PCI bridge not use a own INT?
I just had a new test.Share an interrupt with other devices,it also succeeded.Look like only IRQ18 can not shared to used for it.This is a strange phenomenon.
This could also be a solution - using a different PCIe slot
