Hello ,
I have been trying to install Linux driver for PCAN-USB X6 on a UBUNTU 14.4 machine. I am using peak-linux-driver-8.3
As I understand that this is the version which supports PCAN-USB X6. I built the chardev variant of the driver and the device gets recognized in the system and I see the 6 channels as expected.
But I would like to use the SocketCAN interface and hence tried the following .
1. built the driver using " make –C driver NET=NETDEV_SUPPORT". This does compile the kernel module but the /lib folder is not compiled. This causes the "make install" to fail as some libs are missing. I built the libs from lib folder
and then installed the driver. But the following error pops up when the PCAN-USB X6 box is connected to the system
[18990.985358] usb 1-2: new full-speed USB device number 11 using ohci-pci
[18991.447127] usb 1-2: New USB device found, idVendor=0c72, idProduct=0014
[18991.447131] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[18991.447133] usb 1-2: Product: PCAN-USB X6
[18991.447134] usb 1-2: Manufacturer: PEAK-System Technik GmbH
[18991.486372] pcan: unable to find same usb if
[18991.486389] pcan: device_init() failure err -12
[18991.486396] pcan: probe of 1-2:1.0 failed with error -12
So my question is , does this driver support PCAN-USB X6 in NETDEV mode? IF yes , could you please guide me through the process.
2. I understand that for NETDEV support for PCAN-USB adaptors there is support in the mainline Linux kernel and there is no need for me to install this driver. In my PC the required modules need to be built and inserted
$cat /boot/config-4.2.0-27-generic | grep CAN
CONFIG_CAN=m
CONFIG_CAN_RAW=m
CONFIG_CAN_PEAK_USB=m
If I build and insert the above mentioned modules will PCAN-USB X6 be detected as a net device ? Could you please guide me through this ?
Thanks in Advance
Vineeth
Issue with Linux driver for PCAN-USB X6 version 8.3
- S.Grosjean
- Software Development
Re: Issue with Linux driver for PCAN-USB X6 version 8.3
1/ That's true: when building the driver in "netdev" mode, the lib (as well as the test programs) are useless, so "make install" will fail to install them. The lib is an API that encapsulates the "chardev" interface (open, read, write, ioctl, close) calls. It is obviously useless when building the driver in "netdev" mode. Building and installing a "netdev" driver needs should be done from the "driver" sub-directory. To avoid any "error" during such installation, do a first "normal" (chardev) install, then go into the driver dir, rebuild it and make install it only.
2/ The given message is an error message. Do you have such a message when loading the chardev driver, please?
3/ The PCAN-USB X6 will be natively supported by the next distribution of Linux based system that includes Kernel 4.10.
Stéphane
Stéphane
— Stéphane
- S.Grosjean
Hello again,
As you want to run above the socket-can interface, please find attached a tarball which contains an out-of-tree version of the (future) mainline driver "peak_usb", which supports the PCAN-USB X6 as 6x can network interfaces.
To build this driver:
This should normally create a new "peak_usb.ko" in the current directory. To run it:
1 - be sure to remove the current "peak_usb" module (if any)
2 - be sure to load the can-dev module (if it wasn't before)
3 - Finally load this driver:
You should normally see the 6x can interfces with:
Of course, you HAVE TO remove the "pcan" driver module too...
Don't hesitate to give us any feedback; building this driver might generate errors with your Kernel...
Stéphane
$ tar -xzf peak_usb-2.3.0.tar.gz
$ cd peak_usb-2.3.0
$ make
$ sudo rmmod peak_usb
$ sudo modprobe can-dev
$ sudo insmod peak_usb.ko
$ ls /sys/class/net/
can0 can1 can2 can3 can4 can5
Stéphane
- peak_usb-2.3.0.tar.gz
- Out-of-tree peak_usb driver handling PCAN-USB X6
- (33.44 KiB) Downloaded 587 times
— Stéphane
Hello Stéphane,
I will let you know after I try it out. Thanks a lot.
Vineeth
Vineeth
- S.Grosjean
We have modified pcan v8.3 in order to handle how ohci enumerates the USB devices. Could you please send us an e-mail to linux@peak-system.com (subject, say "OHCI vs. pcan 8.3 beta") so that we will be able t send you back a beta version of pcan.
Thanks for helping in improving pcan!
Stéphane
Stéphane
— Stéphane
