Unable to use PCAN-USB X6 with SocketCAN under Linux
Is this device supported for use with the Linux SocketCAN drivers?
Re: Unable to use PCAN-USB X6 with SocketCAN under Linux
yes, it will be supported with kernel Version 4.9 or higher. If you use an older kernel you have to install our peak-linux-driver 8.3.1 and compile it for NetDev support, or install an out-of-tree kernel driver for the PCAN-USB-X6.
