I am using the PCAN adapter with the 8.1 Linux driver in Ubuntu 16.04. I have implemented SocketCAN support in my application but when writing I get errno=105 "No buffer space available". How can I avoid this?
I have been reading about different calls of setsockopt, ioctl etc but I cannot find any information on how to determine the free space of the write buffer. Any help is appreciated.
Socket write avoiding No buffer space available
- S.Grosjean
- Software Development
Re: Socket write avoiding No buffer space available
There's many reasons why the socketCAN layer cannot flush its internal buffers.
First of all, please give us the result of "cat /proc/pcan" as well as "uname -a".
You might also install the last version of pcan from here:
http://www.peak-system.com/fileadmin/me ... 3.1.tar.gz
Stéphane
Stéphane
— Stéphane
Hi Stéphane,
Thank you for the reply. Here comes the requested information.
I dont think there is any problem with the Peak related stuff.
I just want to know how the determine the state of the tx buffer.
This is maybe more related to SocketCAN than Peak.
If I increase the tx buffer like this "ifconfig can0 up txqueuelen 500"
I dont get the 105 error. It seems to default to 10. I guess that it is 10 frames.
But in my application I want to be able to handle the case when the tx buffer gets full whatever the its size is.
cat /proc/pcan
*------------- Release_20170214_n (8.3.1) Apr 19 2017 20:28:49 --------------
*--------------------- 1 interfaces @ major 246 found -----------------------
32 usb can0 ffffffff 002 0x001c 00000000 00000000 00000000 00000000 0x0000
uname -a
Linux mikael-VirtualBox 4.4.0-72-generic #93-Ubuntu SMP Fri Mar 31 14:07:23 UTC 2017 i686 i686 i686 GNU/Linux
cat /proc/pcan
uname -a
With the latest driver I dont get the error, even with txqueuelen=1. But my request remain. I would like to write robust code but I dont know how to get the status of the tx buffer.
do you use a virtual machine? Then this buffer problem could be related to your Virtual Box USB system Please check that all “guest extension packs” are installed on that VM. We don´t support VM related problems. So please test again in a native Linux system, to see if that problem is based on the virtual system.
- S.Grosjean
Thx for your feedback. AFAIU you're running a Linux system into a virtual box, with a PCAN-USB device connected to. We generally do not support such configuration and generally strongly advice to move on a real Linux machine.
To answer to your request: socket-CAN is (obviously) a socket-based API. There is actually no way to determine the status of the Tx buffer, because socket are historically IP medium oriented. Using the sockets with IP protocols means: 1/ using UDP and thus, knowing that some datagrams may be lost 2/ using TCP and thus, trusting in the (socket) protocol layers to handle lost and/or out-of-order packets. In both cases, Tx buffer size is no longer an issue.
Thus, the only way of controlling CAN frames sending is to handle errno=105 by yourself, then, setting up some (not busy) wait cycles before retrying the same "send()" command. You can have a look to the cansend.c application from the can-utils package to learn more about that.
Stéphane
Stéphane
— Stéphane
Thank you very much for the help. Case closed. I will handle any tx buffer full in my application.
