pcan: pcan_xxxdev_rx(1) failure
I'm using a 3.16.39 kernel with Xenomai 2.6.4 patches. I installed peak driver 7.14 and we used with a pcan-usb device without problems during long time.
One day, it suddenly stop working. Probably it was because I did some upgrade, or whatever. The error code I got was:
pcan: @offset 0: message decoding error -28
As the driver was a bit old I though that it could be a good idea to upgrade so I put 8.3.1. The question was that it worked but after reboot I got:
pcan_xxxdev_rx(1) failed err=-28
So, probably I'm doing some stupid mistake or something obvious that I don't see.
Any idea?
Thanks in advance,
Leopold
Any idea?
Thanks in advance,
Leopold
Re: pcan: pcan_xxxdev_rx(1) failure
just an clarification. I'm not using the Xenomai driver. Just the standard Linux driver. In any case, I have tested it with another kernels (non-RT) and it fails in the same way.
Leopold
Leopold
Please give us the results of:
as well as the FULL output of:
So it is not CAN-USB specific problem, it is USB specific problem.
Didi you use the system in a VM ?
If yes, you have to check that all "guest extension packs" are installed on that VM.
But, finally, we recommend you to run our driver in a native Linux system.
$ uname -a
$ lsusb -d 0c72: -v
$ grep -i 0c72 /lib/modules/`uname -r`/modules.alias
$ cat /proc/pcan
Is a msg that is displayed when processing msgs received from the PCAN-USB only failed.pcan: pcan_xxxdev_rx(1) failed err=-28
$ uname -a
Linux grasp 4.9.0-0.bpo.2-amd64 #1 SMP Debian 4.9.18-1~bpo8+1 (2017-04-10) x86_64 GNU/Linux
Linux spectra 3.16.0-4-amd64 #1 SMP Debian 3.16.39-1 (2016-12-30) x86_64 GNU/Linux
$ lsusb -d 0c72: -v
Bus 004 Device 004: ID 0c72:000c PEAK System PCAN-USB
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 16
idVendor 0x0c72 PEAK System
idProduct 0x000c PCAN-USB
bcdDevice 1c.ff
iManufacturer 0
iProduct 3
iSerial 0
bNumConfigurations 3
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 46
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 200mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 4
bInterfaceClass 0 (Defined at Interface level)
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 20
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 20
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 2
wTotalLength 46
bNumInterfaces 1
bConfigurationValue 2
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 394mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 4
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 20
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 20
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 2
wTotalLength 46
bNumInterfaces 1
bConfigurationValue 3
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 200mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 4
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
Bus 004 Device 003: ID 0c72:000c PEAK System PCAN-USB
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 16
bcdDevice 1c.ff
iManufacturer 0
iProduct 3
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 46
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 200mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 4
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 20
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 20
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 2
wTotalLength 46
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 394mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 4
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 20
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 20
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 2
wTotalLength 46
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 200mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 4
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
alias usb:v0C72p0014d*dc*dsc*dp*ic*isc*ip*in* peak_usb
alias usb:v0C72p0011d*dc*dsc*dp*ic*isc*ip*in* peak_usb
alias usb:v0C72p0012d*dc*dsc*dp*ic*isc*ip*in* peak_usb
alias usb:v0C72p000Dd*dc*dsc*dp*ic*isc*ip*in* peak_usb
alias usb:v0C72p000Cd*dc*dsc*dp*ic*isc*ip*in* peak_usb
alias usb:v0C72p0014d*dc*dsc*dp*ic*isc*ip*in* pcan
alias usb:v0C72p0011d*dc*dsc*dp*ic*isc*ip*in* pcan
alias usb:v0C72p0012d*dc*dsc*dp*ic*isc*ip*in* pcan
alias usb:v0C72p000Dd*dc*dsc*dp*ic*isc*ip*in* pcan
alias usb:v0C72p000Cd*dc*dsc*dp*ic*isc*ip*in* pcan
$ cat /proc/pcan
*------------- Release_20170214_n (8.3.1) May 25 2017 12:47:49 --------------
*--------------------- 2 interfaces @ major 245 found -----------------------
32 usb -NA- ffffffff 000 0x001c 00000000 00000000 00000000 00000000 0x0000
33 usb -NA- ffffffff 000 0x001c 00000000 00000000 00000000 00000000 0x0000
No, I'm not using a VM, I'm using a physical box.
Reason: Inserted Code tags for better readability
I have used again the peak-usb device and then:
$ cat /proc/pcan
32 usb -NA- ffffffff 000 0x0014 0000020d 00000015 000031ac 00006105 0x0002
Reason: Inserted Code tag for better readability
do you use any USB hubs or extension cables in your setup? What kind of CAN hardware/CAN cables do you use on your CAN system, and which baudrate do you use? (pcan32 uses 1Mbit/s while pcan33 is on 500k)
- S.Grosjean
- Software Development
Generally speaking, the -28 error occurs when the Rx FIFO of the driver receiving messages from the hardware is full.
So it appears that the PCAN-USB is always sending messages to the driver and the application is not reading them. These messages can be CAN frames OR status messages. Can you tell us more about your application please? Does it always wait for read from the driver? What are these 525 messages read, please? Moreover, the above says that you have setup the PCAN-USB with a bitrate=1 Mbps. Are you certain that the equipment connected to your CAN bus are all setup with the same bit timings?
When you're running in failure, can you give us the result of this command, please :
Stéphane
Your first line says your application has read 525 CAN msgs from the driver, while it has written 15 CAN messages on the CAN bus. Last column "'status" says your Rx FIFO is full (see pcan.h):$ cat /proc/pcan
#define CAN_ERR_OVERRUN 0x0002 // overrun in receive buffer
$ for f in `ls /sys/class/pcan/pcanusb32/`; do echo -n "$f:"; cat /sys/class/pcan/pcanusb32/$f; done
Stéphane
— Stéphane
I don't use any USB hub or extension cable.M.Maidhof wrote:Hi,
I'm using a robotic hand (Allegro hand) connected directly to the USB-Can from peak.
We are using 1Mbit/s. We have two USB-Can and nothing is connected in the other USB.
Yes, it's a simple application with a loop sending an receiving information about the state of the hand.S.Grosjean wrote:Hello,
Generally speaking, the -28 error occurs when the Rx FIFO of the driver receiving messages from the hardware is full.Your first line says your application has read 525 CAN msgs from the driver, while it has written 15 CAN messages on the CAN bus. Last column "'status" says your Rx FIFO is full (see pcan.h):$ cat /proc/pcan
33 usb -NA- ffffffff 000 0x001c 00000000 00000000 00000000 00000000 0x0000So it appears that the PCAN-USB is always sending messages to the driver and the application is not reading them. These messages can be CAN frames OR status messages. Can you tell us more about your application please?Code: Select all
my problem is that this software was running during the last two years but some upgrade (??) made it failed. It could be a problem of the software or some hide incompatibility with the USB system.
When you're running in failure, can you give us the result of this command, please :Code: Select all
adapter_name:PCAN-USB
@adapter_number:0
adapter_version:2.8
@base:0x0
btr0btr1:0x0014
bus_state:1
clock:8000000
ctrlr_number:0
dev:245:32
devid:255
errors:34325
hwtype:11
init_flags:0x00000002
irq:0
irqs:18292
minor:32
nom_bitrate:1000000
nom_brp:1
nom_sample_point:7500
nom_sjw:1
nom_tq:125
nom_tseg1:5
nom_tseg2:2
power:read:1185
rx_fifo_ratio:100.00
status:0x0002
subsystem:tx_fifo_ratio:0.00
type:usb
uevent:MAJOR=245
MINOR=32
DEVNAME=pcanusb32
write:681
Thanks for check it!!!
- S.Grosjean
Could you please rebuild the pcan driver but in DEBUG mode, that is:
Remove current driver then load new (dbg) one:
Then, run your application. When it fails, do:
Then send us the file /tmp/pcan.txt please.
Stéphane
$ cd peak-linux-driver-8.3.1/driver
$ make clean
$ make DBG=DEBUG
$ sudo make install
$ sudo rmmod pcan
$ sudo modprobe pcan
$ dmesg | grep pcan > /tmp/pcan.txt
Stéphane
— Stéphane
