pcan: pcan_xxxdev_rx(1) failure
- S.Grosjean
- Software Development
Re: pcan: pcan_xxxdev_rx(1) failure
It looks like you're always receiving these CAN messages every 3 ms from the bus:
id=979 len=8
id=980 len=8
id=981 len=8
id=982 len=8
Could you first check if it's normal.
Next, with such a high frequency of reception, you could try to increase the Rx fifo size of the driver, with adding the module arg "rxqsize" to the modprobe options parameter. For example, to setup a size of 5000 entries (instead of 500 which is the default value):
(you should rmmod then modprobe pcan to handle this change).
Next, be sure that your application is able to process more than 1 msg/ms.
Stéphane
id=979 len=8
id=980 len=8
id=981 len=8
id=982 len=8
$ sudo vi /etc/modprobe.d/pcan.conf
options pcan rxqsize=5000
install pcan /sbin/modprobe --ignore-install pcan
Stéphane
— Stéphane
Yes, it's normal. We try to make some control.S.Grosjean wrote:Hi,
id=979 len=8
id=980 len=8
id=981 len=8
id=982 len=8
done
Yes, it worked before.Next, be sure that your application is able to process more than 1 msg/ms.
Now, with your proposed changes is working again. Also, I have decreased the period time to 5 ms (with 3 ms, didn't work). In any case, I will investigate further. Thanks, thanks, thanks. You got me a big light in this issue.
- S.Grosjean
Stéphane
Yep, but you also said that you did some updates... Your application was certainly able to handle such a bus load in your previous environment, while it isn't anymore...Next, be sure that your application is able to process more than 1 msg/ms.
Ok. Don't forget to rebuild (and install) the driver WITHOUT any DBG option.Now, with your proposed changes is working again. Also, I have decreased the period time to 5 ms (with 3 ms, didn't work). In any case, I will investigate further. Thanks, thanks, thanks. You got me a big light in this issue.
Stéphane
— Stéphane
