Problem: No Data on CAN-Bus
USB to CAN Interface
sunbo_ll
Post by sunbo_ll » Tue 7. Nov 2017, 11:27
I've now a problem with IPEH-002021. The adapter worked well with our device together till last week. It can be connected using PCAN-View, but no data can be exchanged any more. The led blinks always and PCAN-View shows the status with OK. The baudrate 1MBit/s is correctly applied.
Softwareentwicklung, OOD/OOP, C/C++, Delphi, Java, QT
Modellierung, Simulation, Datenvisualisierung, Testautomatisierung
Re: Problem: No Data on CAN-Bus
Post by M.Maidhof » Tue 7. Nov 2017, 12:37
as a first check, please measure the transceiver voltages:
http://www.peak-system.com/forum/viewto ... f=120&t=52
sunbo_ll
Post by sunbo_ll » Tue 7. Nov 2017, 13:27
Voltages:
PIN2(CAN-L) vs PIN3(GND), 0V
PIN7(CAN-H) vs PIN3(GND), 5V
It seems that there is an error in the hardware.
Post by M.Maidhof » Tue 7. Nov 2017, 13:43
yes, looks like a broken CAN transceiver PCA82C251T. You can try to replace it (SO-8) if you have some soldering experience.
sunbo_ll
Post by sunbo_ll » Tue 7. Nov 2017, 14:09
Thank you very much. I'll try to do it.
