I installed the driver for Peak PCAN-USB Pro from "https://www.peak-system.com/PCAN-USB-Pr ... .html?&L=1" which is "PeakOemDrv.exe" driver. But after installing it, I'm seeing the message in the device manager that says "The drivers for this device are not installed. (Code 28). There are no compatible drivers for this device. To find a driver for this device, click Update Driver."
I'm not sure if this is the correct driver to install or not, please guide. I'm using PCAN-USB Pro on Windows 10.
Thank you!
Jimit Shah.
Driver Installation Issue: PCAN USB Pro
Re: Driver Installation Issue: PCAN USB Pro
Double POST - you also send this via E-Mail to our support Team! Thread will be deleted later on...
I installed Peak-Drivers 4.1.4 and now it shows the driver for the device needs to start. When I plug in the PCAN-USB Pro (Not FD) it will start blinking Orange.
The driver you use works also for the older USB-Pro Devices (Silver housing)
See manual for the LED Info:
https://www.peak-system.com/produktcd/P ... pdf#page18
Please reboot the PC and try again running PCAN-View
