pcan err=-28
isera
pcan err=-28
Post by isera » Tue 26. Jun 2018, 14:23
I am using the usb pcan to control a motor. Occasionally, I would get the err=-28 in dmesg terminal. Once this error appears, the motor would stop moving. The only way to make the motor to move again via pcan is hard reset the pcan.
The complete error is listed as follows:
pcan: pcan_xxxdev_rx(1) failed err=-28
May I know what does this error mean? I can't find the details in the user manual. Hope you could enlighten me.
Thanks.
David
Re: pcan err=-28
Post by M.Maidhof » Tue 26. Jun 2018, 15:31
Err = -28 => not enough space to push the incoming frame into the Rx Queue.
Looks like your application did not read the RX queue fast enough.
As a workaround you could change the rxqsize parameter (default is 500) to (for example) 1000:
Add the following bold line to “/etc/modprobe.d/pcan.conf”
# options pcan type=isa,sp
options pcan rxqsize=1000
install pcan modprobe --ignore-install pcan
