Change of the channels order with 2 PCAN-miniPCIe FD
I have two PCAN-miniPCIe FD connected in a axiomtek. The axiomtek detect the two miniPCIe correctly but the channels order change aleatorialy when i restart the axiomtek.
If the first PCAN-miniPCI have CAN1 CAN2 CAN3 and CAN4 and the second PCAN-miniPCI CAN5, CAN6, CAN7 and CAN8, sometimes, using pcanview i can see the order CAN1 CAN2 CAN3 CAN4, CAN5, CAN6, CAN7 and CAN8.
Other times i can see the order CAN5, CAN6, CAN7, CAN8, CAN1 CAN2 CAN3 and CAN4.
This is a important problem for me because i work with the channel number.
¿could someone help me with that?
Thanks, Ander
Thanks, Ander
Re: Change of the channels order with 2 PCAN-miniPCIe FD
On Window, you could fix the Channel see this link:
Thanks U.Wilhelm,
I have tried to define the Device ID in the miniPCIe but i do not see the option:
On the other hand, i can see how to change the device id at a peak:
Is there any way to define the identifier in the miniPCIe?
Or is there any other way to fix the order of the channels?
best regards
Ander
best regards
Ander
You are right - sorry !
Here the correct Link for the PCIe based cards:
https://www.peak-system.com/forum/viewt ... Device+fix
Thanks U.Wilhelm,
I try to follow the steps of the link but it seems I do something wrong.
I'm using PCAN-miniPCIe FD:
(0x118 = PCAN-miniPCIe FD)
And I can see the following configuration:
I have configured the regedit:
But when I restart the PC I see the channels without configuring:
Am I getting confused in some step?
best regards
Ander
best regards
Ander
As you can see in the picture that I attached about CAN Hardware I am using PCAN-miniPCIe FD.
In the list that references it says that for PCAN-miniPCIe FD i need 0x118. However I tested with 0x119 and it has not worked.
Could I have made a mistake in another step?
Please export the Registry Key and send it to support@peak-system.com we will check it.
Sorry Uwe.
i must have made some mistake in the tests.
it works correctly.
thanks for all
it works correctly.
thanks for all
No Problem - i also mixed up the miniPCIe FD and the PCIe FD Chip !
