Identifying several PCAN-LIN on a PC
RS-232 to CAN/LIN Interface
R1MARC
Post by R1MARC » Wed 28. Nov 2018, 13:53
I've 2 PCAN-LIN attached to my laptop, through USB-RS232 converter, and then 2 PCAN-LIN CT application.
Is there a way to identify which instance of application goes to which gateway?
The COM port at the bottom of the window can change from one connection to another (USB rules) and, sometimes,bateways are moved from an adapter to the other, crossing the configuration on application.
Re: Identifying several PCAN-LIN on a PC
Post by M.Maidhof » Wed 28. Nov 2018, 14:23
no, there is no option available in PCAN-LIN CT. Probably you can see the differences in the "Data Present in Module" Tab.
R1MARC
Post by R1MARC » Wed 28. Nov 2018, 15:30
Yes it is the method I found, not so simple in fact when using 2 sets of gateway+application.
