Scale & offset values in Micromod configuration Sw
Laurent
Re: Scale & offset values in Micromod configuration Sw
Post by Laurent » Tue 30. Aug 2016, 10:23
Good morning M Lang,
Just to confirm your information, despite the information given in the online help ("Multiplier and offset for the data contents. These may be positive or negative floating point values."), this means that the scale factor can only be an integer and not a float value? I mean that I won't be able to have a scale like 0,1 or 0,05?
This was my original question as a 16 bits value (or 8 bits) defined as an integer is not the same that a 16 bits floating point value (splitted as a sign, exponent and mantissa and with different formats if not IEEE)...
Laurent
Post by G.Lang » Tue 30. Aug 2016, 11:15
Hello Laurent,
the manual is correct, you can also use "floating point values" for the scale and offset.
But you must it type in in the normal decimal format, it´s not possible to type in splitted in sign, exponent and mantissa.
Laurent
Post by Laurent » Tue 30. Aug 2016, 17:18
Ok perfect! Thanks again for your support!
Laurent
