OBD scan tool
Re: OBD scan tool
Post by K.Wagner » Mon 3. Jun 2013, 15:20
In my opinion, an OBD-II simulator can be writen using UDS API as follow:
  1. Start a loop for Packages reading (using UDS_Read).
  2. Only take packages into account that are directed to a defined target address.
  3. Interpret the data within the packages (according with OBD-II specifications)
  4. Send the simulated answer back (using UDS_Write)
(The packetizing for messages larger thatn 8 bytes is done internally by the UDS API)
About Java, well I'm not a java programmer but I think it should not be a big deal if you already implemented a JNI dll anytime.
sebaroesch
Re: OBD scan tool
Post by sebaroesch » Mon 3. Jun 2013, 16:03
Thanks, that sounds promising!
I got access to the beta forum and will have a look at the example. Looks like someone else is also looking for a JNI based approach :)
rohan4pcan
Re: OBD scan tool
Post by rohan4pcan » Fri 27. Sep 2013, 13:33
Any Update on the UDS APIs ? We are also looking for transport layer support for UDS messages . Let me know if any help is required ( beta testing etc.) .
Re: OBD scan tool
Post by K.Wagner » Fri 27. Sep 2013, 14:23
UDS is still in BETA status. You will find more information about how to become a beta tester here, in case you have interest on it.
Re: OBD scan tool
Post by PEAK-Support » Thu 2. Jul 2015, 10:18
UPDATE:
1. The UDS is released and could be found on our WEB Page - Support - API´s
2. The OBD-II Scanner Tool is also available now. Please download the PreRelease version from our Product DVD
http://www.peak-system.com/produktcd
reeferjon
Re: OBD scan tool
Post by reeferjon » Mon 6. Apr 2020, 21:34
Hi.
Is the ODS still in beta or has it been released please.
If so will it work with a PCAN-USB......
I have PCAN-USB at work and need to take a look at a Corsa for a friend.
Re: OBD scan tool
Post by PEAK-Support » Tue 7. Apr 2020, 09:11
If you talk about UDS - it is released since many years - the post from keneth is 7 years old.
Please read also my post from 2015
UPDATE:
Check our Support / Download Section on our WEB page.
reeferjon
Re: OBD scan tool
Post by reeferjon » Tue 7. Apr 2020, 09:35
I do, and thank you for the link......I was going to try this a couple of years ago but it didnt happen.
Im going to use it today.
Its hard when you have propietry software for your daily work job but cant find a resaonablecheap piece of software to check a simple car code.
Thank you for your tool and I will let you know how I get on.
john
Re: OBD scan tool
Post by PEAK-Support » Mon 13. Apr 2020, 12:52
no reply - so we close it her...
