Error testing CAN FD frames PEAK CAN USB X6 Device
6-Channel CAN FD Interface for High-Speed USB 2.0
jibinkurian1246
Re: Error testing CAN FD frames PEAK CAN USB X6 Device
Post by jibinkurian1246 » Tue 4. Jul 2017, 16:21
Hi stephane,
yes, immediately after sending CAN FD Frame ( cansend can0 123##1DEADBEEFDEADBEEF) and listening on the other interface( candump can1 ) leads to error in transmission with Red led's blinking
Post by M.Maidhof » Wed 5. Jul 2017, 09:18
please check the used CAN cables. Looks like the termination resistors are missing on boths ends. Then it could work with lower bitrates, but won´t work with higher bitrates or FD.
jibinkurian1246
Post by jibinkurian1246 » Fri 7. Jul 2017, 16:30
Hi Michael,
Thanks a lot for the information.
Everything works fine after adding termination resistors in the CAN cable.
Jibin
Prasad
Post by Prasad » Thu 22. Aug 2019, 04:10
Hi jibinkurian1246,
Did you use 2 different terminals for cansend and candump?
Why i am asking is even i face the same issue what you faced, i have set the correct baudrate for my CANFD, after sending message via cansend, i dont see any traffic over any channel with candump command.
another thing i want to know about the connections, from my board i have 3 DB9 connectors out of which one i use for power supply, how do i use the other 2 connectors so that i can see my CAN traffic on candump.
I am new to CAN and Linux platform
Thanks for the useful info on this page.
Post by M.Maidhof » Thu 22. Aug 2019, 11:09
Hi Prasad,
which CAN hardware from PEAK do you use? Please post output of "ip link ls" and "cat /proc/pcan"
Prasad
Post by Prasad » Mon 26. Aug 2019, 15:09
Hello Maidhof,
Thanks for the reply. Please find the below screen shot for "ip link ls"
Please let me know if we need to use 2 terminals? If yes, i am using minicom, i am i able to open 2 terminals?
Prasad
Post by Prasad » Mon 26. Aug 2019, 15:12
Some mistake in uploading the image
Please find the same here
Post by M.Maidhof » Mon 26. Aug 2019, 15:35
please answer all my questions:
Prasad
Post by Prasad » Mon 26. Aug 2019, 16:30
Sorry for missing your questions.
Unfortunately i am not using any PEAK related CAN board, as the questions are generic i am trying to get some info from this thread so that it helps me
Post by M.Maidhof » Tue 27. Aug 2019, 09:48
well...this is a PEAK-System Forum, where we discuss all issues related to PEAK products. So I don't think that you will get an answers for your problem with your board. But if you want to have a working system, you can use one of our PCAN products and connect it to your board 8-)
