HowTo install the peak-linux-driver on a RPI Raspbian image
Re: HowTo install the peak-linux-driver on a RPI Raspbian image
Post by M.Heidemann » Thu 18. Nov 2021, 08:29
Thank you for your request.
Our general recommendation still holds true for your kernel version as well:
You'll need to install the kernel headers in order to install the PCAN-Linux driver,
you may want to check the appropiate resources for your Distro on how to install them,
usually under Raspbian that would be done via:
sudo apt install raspberrypi-kernel-headers
Also we do strongly recommend the use of our latest PCAN-Linux driver
version 13:
http://www.peak-system.com/fileadmin/m ... 3.0.tar.gz
For further questions feel free to contact us again.
jeromeh
Post by jeromeh » Mon 28. Mar 2022, 08:57
Raspberry Pi Fundation released a new version of the raspberry pi 4 model b, called "rev 1.5", with new hardware, that need firmware from april 21 or newer.
Is there a solution to make it work now that we are on 5.x kernels ?
Post by M.Maidhof » Mon 28. Mar 2022, 10:02
do you have that new PI module already in use? Do you have any issues with it? If so, please post the problems to be able to help you. We don't have such a module available at the moment.
jeromeh
Post by jeromeh » Mon 28. Mar 2022, 15:33
There is a problem in installing the old raspbian on those raspberries.
However, the peak-linux-driver work flawlessly on the new raspberry and it has been a mistake of mine.
Just following the instructions made my raspberry read and write like a charm.
Post by M.Maidhof » Mon 28. Mar 2022, 16:20
thanks for the info. Meanwhile driver version 8.14 is the latest version:
http://www.peak-system.com/fileadmin/me ... 4.0.tar.gz
BCGelandewagen
Post by BCGelandewagen » Fri 7. Oct 2022, 23:43
Just to confirm that using latest PCAN-Linux driver and through to the instructions worked for socketcan. was able to read/write CAN bus message on RPI 3.0B with PCAN-USB.
