Power-down
matli
Re: Power-down
Post by matli » Wed 10. Feb 2021, 16:30
M.Heidemann wrote:
Thu 22. Oct 2020, 16:31
In this case you can use the wake-up functionality in case you get the return of "4U" (As seen in the code).
This worked well in a unit that I purchased around the time you wrote that. However, in a newly purchased unit, this didn't work. Is it possible that more recent units return something different than 4U? Which codes can we expect? Is the rule that the code should be greater than or equal to 4? Or is it a bit mask? Or something else?
Re: Power-down
Post by M.Heidemann » Thu 11. Feb 2021, 15:59
Thank you for the feedback.
Our most recent Hardware-Revision is Hardware Revision 6,
so you should check for Hardware-Revision >=4, since the wake-up feature
was introduced in Hardware-Revision 4.
Furthermore you could also write the current Hardware-Revision into your greeting message,
this way you can directly obtain information about the hardware revision:
static void  main_greeting ( void)
	CANTxMsg_t  Msg;
	Msg.bufftype = CAN_BUFFER_TX_MSG;
	Msg.dlc      = CAN_LEN8_DLC;
	Msg.msgtype  = CAN_MSGTYPE_STANDARD;
	Msg.id       = 0x404;
	// overwrite byte 0 with FPGA version
	Msg.data8[0] = FPGA_VERSION;
	Msg.data8[1] = HW_GetHwVersion();
	Msg.data8[2] = 0x00;
	Msg.data8[3] = 0x00;
	Msg.data8[4] = 0x00;
	Msg.data8[5] = 0x00;
	Msg.data8[6] = 0x00;
	Msg.data8[7] = 0x00;
	// Send Msg
	CAN_Write ( CAN_BUS1, &Msg);
This example writes the Hardware-Revision into Byte 1 of the greeting messag (byte 0 being the FPGA-Version), for example
the latest hardware-revision 6:
Please report back to us, if this was able to solve your issue.
matli
Re: Power-down
Post by matli » Thu 11. Feb 2021, 16:52
Hi, and thanks for the clarification. Yes, it solves the issue for the units I have been able to test.
What made me a bit confused was the version checking code:
    else if ( hw_version == 12U)
        // hw-version is 4 and 5, added support for wake-up, mechanical mods
        return 4U;
    // hw-version is:
    // 6 final version for wake-up, footprint mods, supply path mods
    return hw_version;
So it's non-trivial to realize how the version number is constructed. (If the internal magic number is 12, then version is 4 or 5, so return 4. Otherwise return the internal number...) But then I simply assume that any number larger than or equal to 4 can safely be put to sleep.
