Hi, I tried doing all the steps again and included NET=NETDEV_SUPPORT, nothing has changed.
Sorry I'm not very versed with htese systems - do I need do uninstall the old driver first somehow?
please reload the driver again
sudo rmmod pcan
sudo modprobe pcan
then please send output of cat /proc/pcan again
sudo rmmod pcan
sudo modprobe pcan
I work together with roitherm, the problem is that the newest (8.3) driver fails to compile for us when Netdev support is enabled - however, previous driver versions compile with netdev support without a problem.
Our build platform is a Raspberry Pi with 4.4.34-v7+ Kernel with matching kernel headers.
Output of 8.3 build:
So right now we're using 8.2, which compiles fine.
Kind regards,
Simon
pi@raspberrypi:~/pcanusb/peak-linux-driver-8.3 $ sudo make NET=NETDEV_SUPPORT PCI=NO PAR=NO ISA=NO PCC=NO DNG=NO
*** Host machine kernel version=4.4.34-v7+
*** Driver kernel version=4.4.34
*** Path to kernel sources=/lib/modules/4.4.34-v7+/build
*** use KBUILD=yes
*** cc version=4.9.2
make -C /lib/modules/4.4.34-v7+/build SUBDIRS=/home/pi/pcanusb/peak-linux-driver-8.3/driver EXTRA_CFLAGS="-I/home/pi/pcanusb/peak-linux-driver-8.3/driver -DNO_DEBUG -DMODVERSIONS -DNO -DUSB_SUPPORT -DNO -DNO_PCIEC_SUPPORT -DNO -DNO -DNO -DNETDEV_SUPPORT -DNO_RT -Wno-date-time" V=0 modules
make[2]: Entering directory '/usr/src/linux-headers-4.4.34-v7+'
CC [M] /home/pi/pcanusb/peak-linux-driver-8.3/driver/src/pcan_netdev.o
In file included from include/linux/workqueue.h:8:0,
from include/linux/srcu.h:34,
from include/linux/notifier.h:15,
from include/linux/memory_hotplug.h:6,
from include/linux/mmzone.h:735,
from include/linux/gfp.h:5,
from include/linux/kmod.h:22,
from include/linux/module.h:13,
from /home/pi/pcanusb/peak-linux-driver-8.3/driver/src/pcan_common.h:57,
from /home/pi/pcanusb/peak-linux-driver-8.3/driver/src/pcan_netdev.c:39:
/home/pi/pcanusb/peak-linux-driver-8.3/driver/src/pcan_netdev.c: In function ‘pcan_netdev_register’:
/home/pi/pcanusb/peak-linux-driver-8.3/driver/src/pcan_netdev.c:874:23: error: ‘struct can_priv’ has no member named ‘restart_timer’
init_timer(&priv->can.restart_timer);
include/linux/timer.h:120:18: note: in definition of macro ‘__init_timer’
init_timer_key((_timer), (_flags), NULL, NULL)
/home/pi/pcanusb/peak-linux-driver-8.3/driver/src/pcan_netdev.c:874:2: note: in expansion of macro ‘init_timer’
scripts/Makefile.build:258: recipe for target '/home/pi/pcanusb/peak-linux-driver-8.3/driver/src/pcan_netdev.o' failed
make[3]: *** [/home/pi/pcanusb/peak-linux-driver-8.3/driver/src/pcan_netdev.o] Error 1
Makefile:1401: recipe for target '_module_/home/pi/pcanusb/peak-linux-driver-8.3/driver' failed
make[2]: *** [_module_/home/pi/pcanusb/peak-linux-driver-8.3/driver] Error 2
make[2]: Leaving directory '/usr/src/linux-headers-4.4.34-v7+'
Makefile:383: recipe for target 'all' failed
make[1]: *** [all] Error 2
make[1]: Leaving directory '/home/pi/pcanusb/peak-linux-driver-8.3/driver'
make[1]: Entering directory '/home/pi/pcanusb/peak-linux-driver-8.3/lib'
cc -o libpcan.so.0.6 -DNO_RT -I. -I../driver -fPIC -shared -Wall src/libpcan.c -Wl,-soname,libpcan.so.0
cc -o libpcanfd.so.0.1 -DNO_RT -I. -I../driver -fPIC -shared -Wall -DPCANFD_OLD_STYLE_API src/libpcanfd.c -Wl,-soname,libpcanfd.so.0
ln -sf libpcanfd.so.0.1 libpcanfd.so
make[1]: Leaving directory '/home/pi/pcanusb/peak-linux-driver-8.3/lib'
make[1]: Entering directory '/home/pi/pcanusb/peak-linux-driver-8.3/test'
cc -DNO_RT -g -I. -I../lib -I../driver src/receivetest.c src/common.c -lpcanfd -L../lib -o receivetest
cc -DNO_RT -g -I. -I../lib -I../driver src/transmitest.cpp src/common.c src/parser.cpp -lpcanfd -lstdc++ -L../lib -o transmitest
cc -DNO_RT -g -I. -I../lib -I../driver src/bitratetest.c src/common.c -lpcanfd -L../lib -o bitratetest
cc -DNO_RT -g -I. -I../lib -I../driver src/filtertest.cpp src/common.c -lpcanfd -lstdc++ -L../lib -o filtertest
cc -DNO_RT -g -I. -I../lib -I../driver src/pcan-settings.c -lpopt -L../lib -g -o pcan-settings
cc -DNO_RT -g -I. -I../lib -I../driver src/pcanfdtst.c -lpcanfd -L../lib -o pcanfdtst
make[1]: Leaving directory '/home/pi/pcanusb/peak-linux-driver-8.3/test'
Kind regards,
Simon
- S.Grosjean
- Software Development
This is a known issue: 8.3 handles the socket-CAN "restart" mechanism while previous versions didn't.
Unfortunately, some (like Canonical) have decided to backport a change from mainline Kernel 4.8+ into (some of) their 4.4-x kernels.
If you don't mind about using this "restart" mechanism, you can run 8.2 as well.
We're working on this issue to be able to build 8.3 in all of the configurations.
Keep intouch.
Stéphane
Keep intouch.
Stéphane
— Stéphane
the new peak-linux-driver-8.3.1 which fixes that issue is available on our Linux driver website:
Make fails...
root@raspberrypi:~/pcan/peak-linux-driver-8.3.1# make NET=NETDEV_SUPPORT
make[1]: Entering directory '/root/pcan/peak-linux-driver-8.3.1/driver'
make[1]: Nothing to be done for 'depend'.
make[1]: Leaving directory '/root/pcan/peak-linux-driver-8.3.1/driver'
*** Host machine kernel version=4.4.38+
*** Driver kernel version=4.4.38
*** Path to kernel sources=/lib/modules/4.4.38+/build
*** use KBUILD=yes
make -C /lib/modules/4.4.38+/build SUBDIRS=/root/pcan/peak-linux-driver-8.3.1/driver EXTRA_CFLAGS=" -I/root/pcan/peak-linux-driver-8.3.1/driver -DNO_DEBUG -DMODVERSIONS -DPARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DDONGLE_SUPPORT -DPCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT -Wno-date-time" V=0 modules
make[2]: Entering directory '/usr/src/linux-headers-4.4.38+'
CC [M] /root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_main.o
CC [M] /root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_fops.o
CC [M] /root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_fifo.o
CC [M] /root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_filter.o
CC [M] /root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_parse.o
CC [M] /root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_sja1000.o
CC [M] /root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_common.o
CC [M] /root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_timing.o
CC [M] /root/pcan/peak-linux-driver-8.3.1/driver/src/pcanfd_core.o
CC [M] /root/pcan/peak-linux-driver-8.3.1/driver/src/pcanfd_ucan.o
CC [M] /root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_pci.o
/root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_pci.c: In function ‘pcan_pci_enable_msi’:
/root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_pci.c:313:2: error: implicit declaration of function ‘pci_enable_msi_range’ [-Werror=implicit-function-declaration]
pa->msi_count = pcan_pci_enable_msi_range(pa->dev, 1, can_count);
/root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_pci.c:324:4: error: implicit declaration of function ‘pci_disable_msi’ [-Werror=implicit-function-declaration]
pci_disable_msi(pa->dev);
cc1: some warnings being treated as errors
scripts/Makefile.build:258: recipe for target '/root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_pci.o' failed
make[3]: *** [/root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_pci.o] Error 1
Makefile:1402: recipe for target '_module_/root/pcan/peak-linux-driver-8.3.1/driver' failed
make[2]: *** [_module_/root/pcan/peak-linux-driver-8.3.1/driver] Error 2
make[2]: Leaving directory '/usr/src/linux-headers-4.4.38+'
Makefile:395: recipe for target 'all' failed
make[1]: Entering directory '/root/pcan/peak-linux-driver-8.3.1/lib'
make[1]: Leaving directory '/root/pcan/peak-linux-driver-8.3.1/lib'
make[1]: Entering directory '/root/pcan/peak-linux-driver-8.3.1/test'
make[1]: Leaving directory '/root/pcan/peak-linux-driver-8.3.1/test'
- S.Grosjean
Please redo your make command as you did previously, that is without any PCI support:
Stéphane
$ make NET=NETDEV_SUPPORT PCI=NO PAR=NO ISA=NO PCC=NO DNG=NO
Stéphane
— Stéphane
Success! Thanks
root@raspberrypi:~/pcan/peak-linux-driver-8.3.1# make NET=NETDEV_SUPPORT PCI=NO PAR=NO ISA=NO DNG=NO
*** use KBUILD=yes
make -C /lib/modules/4.4.38+/build SUBDIRS=/root/pcan/peak-linux-driver-8.3.1/driver EXTRA_CFLAGS=" -I/root/pcan/peak-linux-driver-8.3.1/driver - DNO_DEBUG -DMODVERSIONS -DNO -DUSB_SUPPORT -DNO -DNO_PCIEC_SUPPORT -DNO -DNO -DPCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT -Wno-date-time" V=0 modules
CC [M] /root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_pccard_core.o
CC [M] /root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_pccard.o
CC [M] /root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_usb_core.o
CC [M] /root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_usb.o
CC [M] /root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_usbpro.o
CC [M] /root/pcan/peak-linux-driver-8.3.1/driver/src/pcanfd_usb.o
CC [M] /root/pcan/peak-linux-driver-8.3.1/driver/src/pcan_netdev.o
LD [M] /root/pcan/peak-linux-driver-8.3.1/driver/pcan.o
Building modules, stage 2.
MODPOST 1 modules
CC /root/pcan/peak-linux-driver-8.3.1/driver/pcan.mod.o
LD [M] /root/pcan/peak-linux-driver-8.3.1/driver/pcan.ko
make[1]: Nothing to be done for 'all'.
root@raspberrypi:~/pcan/peak-linux-driver-8.3.1# make install
Info: /lib/modules/4.4.38+/misc exists.
mkdir -p /usr/lib
cp libpcan.so.0.6 /usr/lib
ln -sf libpcan.so.0.6 /usr/lib/libpcan.so.0
ln -sf libpcan.so.0 /usr/lib/libpcan.so
mkdir -p /usr/include
cp libpcan.h /usr/include
chmod 644 /usr/include/libpcan.h
cp libpcanfd.so.0.1 /usr/lib
ln -sf libpcanfd.so.0.1 /usr/lib/libpcanfd.so.0
ln -sf libpcanfd.so.0 /usr/lib/libpcanfd.so
cp libpcanfd.h /usr/include
chmod 644 /usr/include/libpcanfd.h
/sbin/ldconfig
cp receivetest transmitest bitratetest filtertest pcan-settings pcanfdtst /usr/local/bin
root@raspberrypi:~/pcan/peak-linux-driver-8.3.1# modprobe pcan
root@raspberrypi:~/pcan/peak-linux-driver-8.3.1# modprobe can
root@raspberrypi:~/pcan/peak-linux-driver-8.3.1# ip link set can0 type can bitrate 250000
root@raspberrypi:~/pcan/peak-linux-driver-8.3.1# ip link set can0 up
root@raspberrypi:~/pcan/peak-linux-driver-8.3.1# candump can0
can0 0DF805CF [8] 65 53 00 8C 00 5D F3 FF
can0 0DF805CF [8] 66 FF 00 FF FF FF FF FF
can0 19FA04CF [8] 60 7B F1 FD 0A 05 22 06
can0 19FA04CF [8] 61 DC 35 14 0B 00 00 00
can0 19FA04CF [8] 62 00 F2 0A E8 0A 7C BB
can0 19FA04CF [8] 63 8D 0E 00 00 00 00 F2
I also have issues installing the 8.3.1 driver. I use the 4.4.48-v7+ kernel. I installed the kernel headers and the run the installation. The driver can't find the popt.h header.
thanks for helping
Daniel
pi@raspberrypi:~/peak-linux-driver-8.3.1 $ sudo make NET=NETDEV_SUPPORT DNG=NO PCI=NO PCIEC=NO PCC=NO ISA=NO
make[1]: Entering directory '/home/pi/peak-linux-driver-8.3.1/driver'
make[1]: Leaving directory '/home/pi/peak-linux-driver-8.3.1/driver'
*** Host machine kernel version=4.4.48-v7+
*** Driver kernel version=4.4.48
*** Path to kernel sources=/lib/modules/4.4.48-v7+/build
*** use KBUILD=yes
make -C /lib/modules/4.4.48-v7+/build SUBDIRS=/home/pi/peak-linux-driver-8.3.1/driver EXTRA_CFLAGS=" -I/home/pi/peak-linux-driver-8.3.1/driver -DNO_DEBUG -DMODVERSIONS -DPARPORT_SUBSYSTEM -DUSB_SUPPORT -DNO -DNO -DNO -DNO -DNO -DNETDEV_SUPPORT -DNO_RT -Wno-date-time" V=0 modules
make[2]: Entering directory '/usr/src/linux-headers-4.4.48-v7+'
CC [M] /home/pi/peak-linux-driver-8.3.1/driver/src/pcan_main.o
CC [M] /home/pi/peak-linux-driver-8.3.1/driver/src/pcan_fops.o
CC [M] /home/pi/peak-linux-driver-8.3.1/driver/src/pcan_fifo.o
CC [M] /home/pi/peak-linux-driver-8.3.1/driver/src/pcan_filter.o
CC [M] /home/pi/peak-linux-driver-8.3.1/driver/src/pcan_parse.o
CC [M] /home/pi/peak-linux-driver-8.3.1/driver/src/pcan_sja1000.o
CC [M] /home/pi/peak-linux-driver-8.3.1/driver/src/pcan_common.o
CC [M] /home/pi/peak-linux-driver-8.3.1/driver/src/pcan_timing.o
CC [M] /home/pi/peak-linux-driver-8.3.1/driver/src/pcanfd_core.o
CC [M] /home/pi/peak-linux-driver-8.3.1/driver/src/pcanfd_ucan.o
CC [M] /home/pi/peak-linux-driver-8.3.1/driver/src/pcan_usb_core.o
CC [M] /home/pi/peak-linux-driver-8.3.1/driver/src/pcan_usb.o
CC [M] /home/pi/peak-linux-driver-8.3.1/driver/src/pcan_usbpro.o
CC [M] /home/pi/peak-linux-driver-8.3.1/driver/src/pcanfd_usb.o
CC [M] /home/pi/peak-linux-driver-8.3.1/driver/src/pcan_netdev.o
LD [M] /home/pi/peak-linux-driver-8.3.1/driver/pcan.o
MODPOST 1 modules
CC /home/pi/peak-linux-driver-8.3.1/driver/pcan.mod.o
LD [M] /home/pi/peak-linux-driver-8.3.1/driver/pcan.ko
make[2]: Leaving directory '/usr/src/linux-headers-4.4.48-v7+'
make[1]: Entering directory '/home/pi/peak-linux-driver-8.3.1/lib'
make[1]: Leaving directory '/home/pi/peak-linux-driver-8.3.1/lib'
make[1]: Entering directory '/home/pi/peak-linux-driver-8.3.1/test'
src/pcan-settings.c:53:18: fatal error: popt.h: No such file or directory
#include <popt.h>
compilation terminated.
Makefile:149: recipe for target 'pcan-settings' failed
make[1]: *** [pcan-settings] Error 1
make[1]: Leaving directory '/home/pi/peak-linux-driver-8.3.1/test'
Daniel
please read manual of the driver, or have a look into this thread on page 7. You need to install libpopt-dev to build the test applications of our driver.
