questions on pcan-link
Posted: Sat 25. Jan 2014, 18:19
I am possibly interested in PCAN-Link but was not able to get sufficient info from this product's webpage.
1) Does it require one client per physical CAN net? In other words, can the 2 client license only handle up to 2 physical networks?
2) Does PC-Link only stream TCPIP? I note that your new CAN to Ethernet gateway net can stream CAN data packages as either UDP or TCPIP. I am particularly interested in UDP for my application.
3) Do you supply info with PC-Link such that one can convert /use the streaming TCPIP data back into the native format, i.e. can I get to it with the PCAN Basic API? Am thinking this is what the client does--takes TCPIP packetized data and converts it back into PCAN-API format.
4) Is the server portion licensed separately, or is it included free? Are there any limitations as to how many copies one can use, besides that you would have to have a physical device to get to the actual CAN networks?
Suggestion: I noted a reference to a question on PC-Link in a completely different section of the forum. It would be nice to have the links for these in this section , or to move them to this section, so as to consolidate the info on this in one place.
Thanks!!!
Mark
Thanks!!!
Mark
