Java basic example crashes
fengels123
Post by fengels123 » Sun 2. Mar 2014, 10:50
When I try to connect to the USB device, the application crashes by pressing the connect buttton
As channel I selected: PCAN_USBBUS1
Baus Rate: PCAN_BAUD_500K
I am using the 64bit version, JAVA demo 1.8.2 with java version 1.7.0_40
Can anyone help me?
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000007103c60c, pid=9480, tid=6264
# JRE version: Java(TM) SE Runtime Environment (7.0_40-b43) (build 1.7.0_40-b43)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (24.0-b56 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [EMET64.dll+0xc60c]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# An error report file with more information is saved as:
# C:\Users\fengels\AppData\Local\My Local Documents\Workspace\PeakCan\hs_err_pid9480.log
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Re: Java basic example crashes
Post by PEAK-Support » Sun 2. Mar 2014, 22:31
please read here and here - looks like you mix up the 32 and 64 Bit DLLs (JNI and PCANBasic)
fengels123
Post by fengels123 » Mon 3. Mar 2014, 15:09
I copied the dll's (PCANBasic_JNI.dll and PCANBasic.dll)in to the right dir c:\windows\system32 for the 32 bit files and C:\Windows\SysWOW64 for the 64 bit file, still did not work
I am using eclipse and set the path in the buidpath, but still the same error.
(libraries are also in C:\Users\engelsflm\AppData\Local\My Local Documents\Workspace\PeakCan\libs\win64)
Post by PEAK-Support » Mon 3. Mar 2014, 15:35
We have just tested it here with W7 and W8.1 on 32 and 64 Bit (both with 32Bit RT and on 64Bit also with 64Bit RT)
We use NetBeans Developer Environment - works fine - so it looks like a Eclipsed related problem - please ask Eclipse community. Our LIB, the JNI, PCANBasic DLL and also the Sample Code works fine.
compauer
Post by compauer » Thu 13. Mar 2014, 13:29
Had the same problem.
For me it helped to download the latest JDK.
Post by PEAK-Support » Thu 13. Mar 2014, 13:40
Works fine with Java 1.7_21 RT 32 & 64 Bit
64BitRuntime on W7 64Bit OS
32BitRuntime on W7 64Bit OS
