Page 1 of 2
PCAN on cubietruck driver installation issues
Posted: Tue 4. Mar 2014, 11:18
by compauer
I try to install the driver for PCAN on a Cubietruck Debian 7.1 wheezy. My Kernel Version is 3.4.61+, and I installed the Kernel Linux Header for 3.2.0-4-all because I didn't find a version for 3.4.61 in my repo. Don't know if it is important for the next steps. At the beginning on the command 'make clean' I get an Error like this:
make[1]: Entering directory `/root/Desktop/peak-linux-driver-7.10/driver'
Makefile:102: *** "Can't find /include/linux/version.h". Stop.
make[1]: Leaving directory `/root/Desktop/peak-linux-driver-7.10/driver'
make[1]: Entering directory `/root/Desktop/peak-linux-driver-7.10/lib'
rm -f src/*~ src/*.o *~ *.so.*
make[1]: Leaving directory `/root/Desktop/peak-linux-driver-7.10/lib'
make[1]: Entering directory `/root/Desktop/peak-linux-driver-7.10/test'
rm -f src/*~ src/*.o *~ receivetest transmitest bitratetest filtertest pcan-settings
make[1]: Leaving directory `/root/Desktop/peak-linux-driver-7.10/test'
So what can I do know?
Edit: Installed the linux-headers-3.4.61, still same error (finding it on /usr/src/)
Re: PCAN on cubietruck driver installation issues
Posted: Tue 4. Mar 2014, 11:39
to build our driver, you need the kernel headers of the installed kernel version, using a different kernel header will not work!
Posted: Tue 4. Mar 2014, 12:25
by compauer
M.Maidhof wrote:Hi,
I already installed the kernel headers (a folder 'linux-headers-3.4.6.1-030461' appeared in /usr/src/). How can I make sure, that the right kernel headers are used?
Edit:
An Error is coming when I'm typing this command:
dpkg -i linux-headers* linux-image*
(Reading database ... 92613 files and directories currently installed.)
Preparing to replace linux-headers-3.4.61-030461 3.4.61-030461.201309080234 (using linux-headers-3.4.61-030461_3.4.61-030461.201309080234_all.deb) ...
Unpacking replacement linux-headers-3.4.61-030461 ...
dpkg: error processing linux-headers-3.4.61-030461-generic_3.4.61-030461.201309080234_i386 (--install):
package architecture (i386) does not match system (armhf)
dpkg: error processing linux-headers-3.4.61-030461-generic_3.4.61-030461.201309080234_i386.deb (--install):
dpkg: error processing linux-image-3.4.61-030461-generic_3.4.61-030461.201309080234_i386.deb (--install):
Setting up linux-headers-3.4.61-030461 (3.4.61-030461.201309080234) ...
Errors were encountered while processing:
Edit2:
Is it right that i used a i386 package instead of an ARM package? If yes, how can I find/install the right headers for ARM?
Posted: Tue 4. Mar 2014, 15:02
this question is not related to our PEAK Linux driver, please contact the support of your Linux distribution. We don´t know that system
Posted: Tue 11. Mar 2014, 13:55
by compauer
M.Maidhof wrote:Hi,
So I installed the right kernel headers. It also found the version.h
Now I get a new Error by typing "make clean":
cpp: error: /include/linux/utsrelease.h: No such file or directory
cpp: warning: '-x c' after last input file has no effect
cpp: fatalr error: no input files
compilation terminated.
That utsrelease.h is not in the directory
Posted: Tue 11. Mar 2014, 16:15
please search for that file in your kernel headers. With the given information it is impossible to help you with your problem.
Posted: Wed 12. Mar 2014, 15:01
by compauer
M.Maidhof wrote:Hi,
So finally I found the needed h-files from the include/generated folder and copied it to my linux-headers. Now I wanted to do the command "make" in the peak-folder direction. So a new Error appeared:
make[1]: Entering directory `/home/linaro/Desktop/peak-linux-driver-7.10/driver'
make[1]: *** No rule to make target `depend'. Stop.
make[1]: Leaving directory `/home/linaro/Desktop/peak-linux-driver-7.10/driver'
*** Host machine kernel version=3.4.79
*** Driver kernel version=3.4.79+
*** Path to kernel sources=
*** use KBUILD=yes
make -C SUBDIRS=/home/linaro/Desktop/peak-linux-driver-7.10/driver EXTRA_CFLAGS="-I/home/linaro/Desktop/peak-linux-driver-7.10/driver -DNO_DEBUG -DMODVERSIONS -DPARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DDONGLE_SUPPORT -DPCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT " V=0 modules
make: Entering an unknown directory
make: *** SUBDIRS=/home/linaro/Desktop/peak-linux-driver-7.10/driver: No such file or directory. Stop.
make: Leaving an unknown directory
make[1]: *** [all] Error 2
make[1]: Entering directory `/home/linaro/Desktop/peak-linux-driver-7.10/lib'
cc src/libpcan.c -fPIC -shared -O2 -Wall -Wl,-soname,libpcan.so.0 -lc -I. -I../driver -DNO_RT -o libpcan.so.0.6
make[1]: Leaving directory `/home/linaro/Desktop/peak-linux-driver-7.10/lib'
make[1]: Entering directory `/home/linaro/Desktop/peak-linux-driver-7.10/test'
cc src/receivetest.c src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o receivetest -lpcan -DNO_RT
cc src/transmitest.cpp src/common.c src/parser.cpp -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o transmitest -lpcan -lstdc++ -DNO_RT
cc src/bitratetest.c src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o bitratetest -lpcan -DNO_RT
cc src/filtertest.cpp src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o filtertest -lpcan -lstdc++ -DNO_RT
cc src/pcan-settings.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o pcan-settings -lpopt -g
src/pcan-settings.c:49:18: fatal error: popt.h: No such file or directory
make[1]: *** [pcan-settings] Error 1
make[1]: Leaving directory `/home/linaro/Desktop/peak-linux-driver-7.10/test'
What could be the problem of this errors?
Posted: Wed 12. Mar 2014, 16:43
in which directory did you call the make? Please use the driver directory of our linux driver. Which parameter did you use in your make call, please see info in the Raspberry Pi thread.
Posted: Thu 13. Mar 2014, 08:03
by compauer
M.Maidhof wrote:in which directory did you call the make? Please use the driver directory of our linux driver. Which parameter did you use in your make call, please see info in the Raspberry Pi thread.
I called make in the peak-linux-driver-7.10 folder. I also used the peak-linux-driver-7.10/driver directory. Just wrote "make", but also tried "make NET=NO PCI=NO PAR=NO ISA=NO PCC=NO DNG=NO DBG=DEBUG"
Tried on version 7.10, 7.8 & 7.7
If I call "make" in the peak-linux-driver-7.10/driver directory I´m getting this error:
*** use KBUILD=yes
make: *** [all] Error 2
Posted: Fri 14. Mar 2014, 08:03
by compauer
Do you have any advice Michael? Really need that working :-/
